In any of the menu definitions, the GCL and OFF routines are run first, which is supposed to turn off osnaps (osnaps are typically on at this point), then it runs the series of commands, then runs CLR, which turns the osnaps back on. I tried what MiD-AwE wrote, and I still get the same error. Im not sure what Im doing wrong, do you have any ideas on what I can change to eliminate this error?
