Visual LISP, AutoLISP and General Customization
Lisp edit help wanted
2 REPLIES 2
brendon_butler
317 Views, 2 Replies
Hi all,
I have this Lisp routine that I took from this site previously, but would like a modification made. I'm hoping somebody could possibly help me out.
So, the below routine simply adds a comma as a suffix to text. However, I would like it to now be added as a prefix.
(defun c:addcomma (/ olderr e sm)
  (setq olderr *error*)
  (defun *error* (msg)
    (if (/= msg "Function cancelled")
      (prompt (strcat "\nError: " msg))
    (setvar "SNAPMODE" sm)
    (setq *error* olderr)                           ;Restore old *error* handler
    (princ)
  (setq sm (getvar "SNAPMODE"))
  (setvar "SNAPMODE" 0)
  (while (setq e (car (nentsel "\nLocate text to add comma: ")))
    (if (member (strcase (cdr (assoc 0 (entget e)))) '("TEXT" "ATTRIB" "MTEXT"))
      (entupd (cdr (assoc -1 (entmod (subst (cons 1 (strcat (cdr (assoc 1 (entget e))) ","))(assoc 1 (entget e))(entget e))))))
  (princ)
Thanks in advance for any help given!
Brendon
2 REPLIES 2
BeKirra
in reply to: brendon_butler
Try the code modified from your post:
brendon.butler wrote:
Hi all,
    (princ)
      (entupd (cdr (assoc -1 (entmod (subst (cons 1 (strcat (cdr "," (assoc 1 (entget e)))))(assoc 1 (entget e))(entget e))))))
  (princ)
Brendon
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
    (princ)
      (entupd (cdr (assoc -1 (entmod (subst (cons 1 (strcat ","  (cdr (assoc 1 (entget e)))))(assoc 1 (entget e))(entget e))))))
  (princ)
AutoCAD Inside the Factory
