LISP - dimension text offset property
Dear community,
I'm trying to adapt another LISP for my purpose. I would like to set the text offset of the selected dimensions (via TextGap) to two possible variants (5.5 and 1.5). Please let me know what is wrong here, because unfortunately it does not work.
(defun c:DimTextOffset ( / sel )
   (if (ssget "_:L" '((0 . "DIMENSION")))
       (progn
           (vlax-for obj
               (setq sel (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object))))
               (if (= acunder (vla-get-TextGap obj))
                   (vla-put-TextGap obj 5.5)
                   (vla-put-TextGap obj 1.5)
           (vla-delete sel)
   (princ)
(vl-load-com) (princ)
Many thanks in advance
dlanorh
two things I see.
1. acunder = nil. It is never set anywhere so instead of
you could
(not (vla-get-TextGap obj))
2. You're not updating the object
(vla-update obj)
after the if statement.
I am not one of the robots you're looking for
ahsattarian3
Do we have such a thing for Text Objects  ????
Kent1Cooper
To do what with them?  The TextGap property is part of Dimension objects, defining the space between the dimension line and the text part.  Since Text Objects have no other component to have a distance from, what do you want to do?
Kent Cooper, AIA
