Lisp Delete lines next to circles.
manasi4532
Message 1 of 15
manasi4532
Is there a way to delete specific objects that have circles attached to them? I've attached an example.
Thank you so much
Accepted solutions (3)
Replies (14)
Message 2 of 15
EnM4st3r
my approach:
ssget objects via circle's bounding box -> check for exactly only one intersection point
(defun c:test123 (/ sel ssresult pt1 pt2 ss i ent)
  (setq sel (ssget '((0 . "Circle"))))
  (setq ssresult (ssadd))
  (if (setq sel (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object))))
    (progn
      (vlax-for obj sel
        (vla-getboundingbox obj 'pt1 'pt2)
        (setq ss (ssget "_C"
                    (vlax-safearray->list pt1)
                    (vlax-safearray->list pt2)
                    '((0 . "~Circle"))
        (setq i 0)
        (while (and ss (< i (sslength ss)))
          (setq ent (ssname ss i))
          (if (= 1 (length (LM:intersections obj (vlax-ename->vla-object ent) acExtendNone)))
            (ssadd ent ssresult)
          (setq i (1+ i))
      (vla-delete sel)
  (sssetfirst nil ssresult)
  (princ)
;; Intersections  -  Lee Mac
;; Returns a list of all points of intersection between two objects
;; for the given intersection mode.
;; ob1,ob2 - [vla] VLA-Objects
;;     mod - [int] acextendoption enum of intersectwith method
(defun LM:intersections ( ob1 ob2 mod / lst rtn )
    (if (and (vlax-method-applicable-p ob1 'intersectwith)
             (vlax-method-applicable-p ob2 'intersectwith)
             (setq lst (vlax-invoke ob1 'intersectwith ob2 mod))
        (repeat (/ (length lst) 3)
            (setq rtn (cons (list (car lst) (cadr lst) (caddr lst)) rtn)
                  lst (cdddr lst)
    (reverse rtn)
Message 3 of 15
manasi4532
Works almost fine But select only lines. I also want it to select additional adjacent circles. Is it possible? Select Line and Circle . Very Thank you.
Message 4 of 15
EnM4st3r
change line 18 to
(progn (ssadd ent ssresult)(ssadd (vlax-vla-object->ename obj) ssresult))
Message 5 of 15
manasi4532
Thank you for help .
Message 6 of 15
manasi4532
I have a problem. Some parts are not working.
Message 7 of 15
EnM4st3r
when you zoom in you can see that these lines and circles are acutually not touching each other
Message 8 of 15
manasi4532
Can we adjust it to choose places that are close to each other?
Message 9 of 15
EnM4st3r
dont know if there is a easy way for that. maybe start a new post?
Message 10 of 15
EnM4st3r
one could possibly use modifier to extend one entity but maybe this will result in always 2 intersection points so idk
Message 11 of 15
Kent1Cooper
@manasi4532 wrote:
Is there a way to delete specific objects that have circles attached to them? ....
Given that wording, I would do it by selecting the Lines [and if what you're looking for would always end at a Circle, other kinds of things -- Arcs, open-ended Polylines, etc.], not the Circles.  An (ssget) function using a little crossing window built around each end of a Line [etc.], and looking for Circles, would get around the ones that don't quite touch [you would need to decide on a fuzz distance].  Does that sound like it would do what you want?
Kent Cooper, AIA
Message 12 of 15
Kent1Cooper
@Kent1Cooper wrote:
... I would do it by selecting the Lines [and ... other kinds of things -- Arcs, open-ended Polylines, etc.], not the Circles.  An (ssget) function using a little crossing window built around each end ... would get around the ones that don't quite touch [you would need to decide on a fuzz distance].  ....
For example, this worked in your sample drawing, including when I replaced a few of the connecting Lines with Arcs or open-ended Polylines/Splines/Ellipses.  I used a diagonal fuzz distance [for looking for Circles at open ends] of 0.1 units, which seemed appropriate for your drawing, but you can edit that.
(vl-load-com)
(defun C:DOEC ; = Delte Objects Ending at Circles [and the Circles]
  (/ getcirc ss delss n ent)
  (defun getcirc (pt)
    (ssget "_c" (polar pt (* pi 1.25) 0.1) (polar pt (/ pi 4) 0.1) '((0 . "CIRCLE")))
      ;; EDIT the 0.1 for crossing-window diagonal fuzz distance
  ); defun
  (if
    (setq ss
      (ssget "_:L" ; on unlocked Layer(s) only
        (list
          '(-4 . "<OR")
            '(0 . "LINE,ARC"); any [always open-ended]
            '(-4 . "<AND"); Pline or Spline not closed
              '(0 . "LWPOLYLINE,SPLINE") '(-4 . "<NOT") '(-4 . "&") '(70 . 1) '(-4 . "NOT>")
            '(-4 . "AND>")
            '(-4 . "<AND"); Ellipse not closed
              '(0 . "ELLIPSE")
              '(-4 . "<NOT") '(-4 . "<AND") '(41 . 0.0) (cons 42 (* pi 2)) '(-4 . "AND>") '(-4 . "NOT>")
            '(-4 . "AND>")
          '(-4 . "OR>")
        ); list
      ); ssget
    ); setq
    (progn ; then
      (setq delss (ssadd)); initially empty
      (repeat (setq n (sslength ss)) ; then
        (setq ent (ssname ss (setq n (1- n))))
        (foreach end (list (vlax-curve-getStartPoint ent) (vlax-curve-getEndPoint ent))
          (if (setq ss2 (getcirc end))
            (progn (ssadd ent delss) (ssadd (ssname ss2 0) delss))
          ); if
        ); foreach
      ); repeat
      (if (> (sslength delss) 0)
        (command "_.erase" delss ""); then
        (prompt "\nNo Circle(s) found at ends of selected object(s)."); else
      ); if
    ); progn
    (prompt "\nNo open-ended object(s) selected."); else
  ); if
  (prin1)
Kent Cooper, AIA
Message 13 of 15
manasi4532
Thank you very much for your help. If I want to delete only the lines and circle that are close to the circle, how can I modify the command?
Message 14 of 15
Kent1Cooper
I'm not sure what you mean by "the lines and circle that are close to the circle."  Would you have Circles close to other Circles, without linking Lines?  Give another example drawing with before and after, including both situations where things should be deleted and some that should not be deleted.
Kent Cooper, AIA
Message 15 of 15
manasi4532
The command works fine. I forgot to set polyline to close so it caused the command to delete the polyline. Now I changed the setting and fixed it. Thankyou somuch
