LISP cut block on layer with polyline
Fleww
Message 1 of 15
Fleww
Hi, I need LISP for my work so i can do this. From attachment "not cuted bad version how we get it" is version1 and I need it to make "Cut good version how we want it" make it version2.
So I need layer SERVICEBOX to be cutted in whole drawing to the layer Building navigated by layer Michror which is crossing that Building layer.
Is this possible, can someone help me please? This is very needed for my work. ❤️ 🙏
Replies (14)
Message 2 of 15
Kent1Cooper
I'm confused.  By "cut" do you mean "move"?  Or "trim"?  If you mean "trim," the Layer called "SERVICEBOX" in the "good" drawing is not what has been trimmed to the "Building" outline, but rather the "Michrorohr" Layer [which is spelled differently in your Message than in the drawings].  That is why I suspect "cut" means "move," because that is what has been done with things on the "SERVICEBOX" Layer, as it has been renamed from one drawing to the other -- there is no  "SERVICEBOX" Layer in the "bad" drawing, to have things on it moved [or trimmed?].  And in the "good" drawing, two of the Blocks near the middle do not have their insertion points on the "Building" Layer outline, as I think is your intent.  Are they not located where they should be, or is there some other reason they are where they are?  Or am I misunderstanding your description?  Is there someone more fluent in English who can write a description for you?
Kent Cooper, AIA
Message 3 of 15
Fleww
Kent1Cooper you have total right and Im sorry for confusing post.
 I thought the drawing would reveal everything.
 Yes I thought exactly what you asked if its true. I upload new drawing with corrected name SERVICEBOX which you noticed :), my fault. It just need to be on good version, I think you dont need more explanations right? Very sorry for first confusing message.
Message 4 of 15
WeTanks
don't need LISP
Try my method?
Please refer to the attached documnet.
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
Message 5 of 15
Kent1Cooper
Still true from before:
Also, some of the Blocks are connected with two Lines and a Point to the Trench path, but some by only one Line, making it very difficult to imagine how a routine could figure out what to do.  Those with a Point and a second Line all seem to end up with those at the insertion point of the Block on the Building perimeter, and the Line is of zero length -- is that really what you want?
Kent Cooper, AIA
Message 6 of 15
Fleww
Yes, thats what i need.
Message 7 of 15
marko_ribar
Just stab in the dark...
Have you tried command, or ACET Express Tool : CLIPIT... It should clip blocks with some curve and I suppose LWPOLYLINE should be very acceptable...
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 8 of 15
Kent1Cooper
If those two are treated as it seems you want the rest treated [i.e. Trim the Line that crosses the Building perimeter, and Move the Block so its insertion point is at the new Trimmed endpoint], then you would end up with this:
If there is to be any hope of figuring out how to instruct a routine to do what you want, it will be necessary to have consistent criteria that it can use to decide [for example, among other things] whether or not to do that.  It occurred to me that maybe those should not be Moved because they have only one Line connecting to the Trench line, with no bend and no Point object.  But that can't be it, because there is another like that at the top, and unlike these two, that one is Moved in your "good" drawing.
Kent Cooper, AIA
Message 9 of 15
Fleww
  I need Lisp that will move and cut layer Servicebox(block) through layer which is connected to it in this case Microrohr(line), to the dot where it cross the line on layer Building(polyline).
This would help me alot in life, I just move it manualy for years at work.:/
Message 10 of 15
Kent1Cooper
What makes the two in the middle [-50 and -60 endings] different, so that they should not be changed as all the rest are?
Kent Cooper, AIA
Message 11 of 15
Fleww
thats my bad in presentation. forget about that 2. sorry for that 🙂
Message 12 of 15
Fleww
Can someone help me to solve this please?:) I tryed on whole internet and chatgpt4 but couldnt reach it. 😕
Message 13 of 15
Kent1Cooper
@Fleww wrote:
Can someone help me to solve this please? ....
Not I without more answers to questions raised.
Kent Cooper, AIA
Message 14 of 15
Fleww
forgot about that two (-50 and -60) I forgot to cut them on building too like others.
Message 15 of 15
Fleww
I know this is so complicated. thanks anyway 🙏😥
