Lisp creat script batch publish Multiple File
Vuxvix
Message 1 of 29
Vuxvix
Hi!
I'm trying to fix the attached lisp to do publishing for all files in the folder.
Is there any other function to open Pop-up that can paste the path link instead of selecting the path like lisp is using. It will save more time.
Looking forward to helping. Thanks
Replies (28)
Message 2 of 29
paullimapa
Would this help
http://www.lee-mac.com/directorydialog.html
Paul Li
IT Specialist
@The Office
Message 3 of 29
Vuxvix
Hi
Can you give more specific instructions?
I run lisp with the bits in the list. Then what needs to be done?
Message 4 of 29
paullimapa
What function do you have in mind that will let you get the path where the drawings are so you can paste it into your lisp code?
Currently your code shows this to pop up a window to select a folder:
  (setq folderName
  (browsefolder "Select folder to perform batch job: ")
If you know exactly what the path should be then just replace the above with this:
; if you know the path will always be C:\Autodesk
  (setq folderName "C:\\Autodesk\\")
If you want the opportunity to enter the path at the command line then change to this:
  (setq dwgprefix (getvar"dwgprefix")) ; set default path to current dwg path
  (while (not folderName)
   (setq folderName (getstring (strcat "\nEnter folder to perform batch job <" dwgprefix ">: ")))
   (if (eq folderName "") ; if enter
     (setq folderName dwgprefix) ; then use default path
     (if (not (vl-file-directory-p folderName)) ; else check if path entered exists
       (setq folderName nil) ; if no path found then start over
       (if(not(eq "\\" (substr folderName (strlen folderName)))) ; else check if slash at end
         (setq folderName (strcat folderName "\\")) ; if not then add
     ) ; if folderName
   ) ; if enter
  ) ; while
Paul Li
IT Specialist
@The Office
Message 5 of 29
Ar_vxv
Hi!
Within my own limited abilities. I combined Lee-Mac's lisp to be able to paste path links.
(setq folderName
  (LM:OFD "Select folder to perform batch job: " nil 16)
I noticed this is "Open folder dialog". The desired window in my question is "Open File dialog".
Here is the version: Incorporate your lisp hint. but something is wrong. so lisp doesn't work.
(defun c:PAD2 (/ dwgs file dwgName scrFile folderName)
     ) ; if folderName
   ) ; if enter
  ) ; while
  (setq scrFile (open (strcat folderName "\\PAD.scr") "w"))
  (foreach file dwgs
 (setq dwgName (strcat "\"" folderName "\\" file "\""))
 (write-line ".Open" scrFile)
 (write-line dwgName scrFile)
 (write-line "_.Autopublish  " scrFile)
 (write-line "(command)" scrFile)
 (write-line ".zoom e" scrFile)
 (write-line "_.CLOSE _Y " scrFile)
  (close scrFile)
  (command ".script" (strcat folderName "\\PAD.scr"))
  (princ)
Message 6 of 29
paullimapa
Ok, found the error because I added a slash at end of folderName
Remove this section of code:
     ) ; if folderName
   ) ; if enter
  ) ; while
& replace with this:
  (setq dwgprefix (substr dwgprefix 1 (1- (strlen dwgprefix)))) ; drop slashes at end
       (if(eq "\\" (substr folderName (strlen folderName))) ; else check if slash at end
         (setq folderName (substr folderName 1 (1- (strlen folderName)))) ; if so then drop
     ) ; if folderName
   ) ; if enter
  ) ; while
Paul Li
IT Specialist
@The Office
Message 7 of 29
Ar_vxv
error: File load canceled
;;; Function to browse folder
;;; This code was originally posted by kpblc2000 in AUGI AutoLisp Forum
(defun browsefolder (title / shlobj folder fldobj)
  (vl-load-com)
  (setq
 shlobj (vla-getinterfaceobject
   (vlax-get-acad-object)
   "Shell.Application"
 folder (vlax-invoke-method shlobj 'OFD 0 title 0)
  (vlax-release-object shlobj)
  (if folder
 (progn
   (setq
 fldobj (vlax-get-property folder 'self)
 folderName (vlax-get-property fldobj 'path)
   (vlax-release-object folder)
   (vlax-release-object fldobj)
   folderName
(princ "\nBatchJob is loaded, Type BatchJob to run.")
(princ)
;;; Main program, command: batchjob                            ;;
;;; old version of line 106:                                   ;;
;;; (browsefolder "Select folder to perform batch job: ")      ;;
     ) ; if folderName
   ) ; if enter
  ) ; while
  (foreach file dwgs
  (close scrFile)
  (princ)
Message 8 of 29
paullimapa
You missed the line of code that collects the dwgs from the folderName path
Also I dropped the browsefolder routine since you no longer need this:
; pad2 enter dwg path, create & run script file
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-creat-script-batch-publish-multiple-file/m-p/12217609#M454238
(princ "\nPAD2 is loading...")
(defun c:PAD2 (/ dwgprefix dwgs file dwgName scrFile folderName)
     ) ; if folderName
   ) ; if enter
  ) ; while
  ; need to include the code below to get list of dwg files
  (setq dwgs (vl-directory-files folderName "*.dwg"))
  (foreach file dwgs
  (close scrFile)
; (startapp "Notepad" (strcat folderName "\\PAD.scr")) ; if needed open script file for editing
  (princ)
) ; defun
(princ "\nSuccessfully loaded. Type PAD2 to run.")
(princ)
Paul Li
IT Specialist
@The Office
Message 9 of 29
Ar_vxv
Hi Paul!
Although it is a "filedia 0" format, it is sufficient for this lisp. Thanks a lot!
Message 10 of 29
paullimapa
Glad to have helped…cheers!!!
Paul Li
IT Specialist
@The Office
Message 11 of 29
Ar_vxv
I encountered an issue while using this lisp to export PDFs for multiple drawings. Some of the drawings have layouts that do not have a "Page setup" assigned. Consequently, the script stops running.
How to edit the script - Let it override a "Page setup" (which may need to be imported from a template file since the dwg file does not have any Page setup) when exporting the PDF file.
Currently, I am using the "Autopublish" command to automatically export the drawing to PDF without modifying any settings. Should I consider an another way?
_.Autopublish
(command)
.zoom e
_.CLOSE _Y
Message 12 of 29
paullimapa
here's a link to a web page with a number of pagesetup lisp functions:
you can use getPageSetupName to check if there's a named pagesetup in the current layout.
if not, then use (command "._-PSETUPIN" filename "*") to import all from another dwg or a specific pagesetup before proceeding with autopublish
Paul Li
IT Specialist
@The Office
Message 13 of 29
Ar_vxv
Hi! Please help me fixed it
1-I use this lisp to apply  Page Setup for all layouts after Psetupin to . But it doesn't work.
; name - the Page Setup Name
; all - a flag, T for all nil for current layout
(defun SetNamePageSetupAllLayouts (name all / lst)
   (or adoc (setq adoc (vla-get-ActiveDocument (vlax-get-acad-object))))
   (if (vl-position
          name
          (vlax-for pltcfg (vla-get-plotconfigurations adoc)
             (setq lst (cons (vlax-get pltcfg 'Name) lst))
      (progn
         (vlax-for layt (vla-get-Layouts adoc)
            (if (/= (vla-get-name layt) "Model")
               (if all
                  (vla-copyfrom layt (vla-item (vla-get-PlotConfigurations adoc) name))
                  (if (= (vla-get-name layt) (getvar 'ctab))
         (vla-Regen adoc acActiveViewport)
To call the main function:
; to change to PageSetup eg:"PDF.A1" all layouts
(defun c:PS2A nil
   (SetNamePageSetupAllLayouts "PDF.A1" T)
   (princ)
; to change to PageSetup eg:"PDF.A1" just the active layout
(defun c:PA21 nil
   (SetNamePageSetupAllLayouts "PDF.A1" nil)
   (princ)
2- In line 2: "*" do not insert all page setup. Does it only work with specific page setup?
 (write-line "(command "._-PSETUPIN" Yaesu.dwt "*")" scrFile)
 (write-line "PS2A " scrFile)
 3-How can I incorporate Lisp-1 into lisp-2. To be able to put the values: template file, page setup at the beginning of the lisp file
look like
(defun c:PS2A nil
   (princ)
(defun c:PA21 nil
   (princ)
Message 14 of 29
paullimapa
(SetNamePageSetupAllLayouts "PDF.A1" T) works for me so I'm not sure what's not working for you.
Perhaps attach your Yaesu.dwt so I can see if you actually have a pagesetup named PDF.A1
Next change this:
to this:
(write-line "(command \"._-PSETUPIN\" \"Yaesu.dwt\" \"*\")" scrFile)
Also change this:
to this:
(write-line "(c:PS2A)" scrFile)
finally the first write-line statement should be this:
(write-line "(load\"SetNamePageSetupAllLayouts\")" scrFile)
Just make sure SetNamePageSetupAllLayouts.lsp is saved in one of the AutoCAD's Support File Search PathTrusted Locations so load function will work.
Paul Li
IT Specialist
@The Office
Message 15 of 29
Ar_vxv
In case some Drawings have Page setup, when loading this script
Page setup "PDF.A1" already exists. Redefine it? [Yes/No] <N>: *Cancel*
how to Yes or No for all !?
Message 16 of 29
paullimapa
One way is to test if pagesetup PDF.A1 is already in the current dwg and only run psetupin if it's not
here's a function (get_pgsetup_lst) which returns a list of all pagesetup names in current dwg:
(defun get_pgsetup_lst (/ pgsob1 pgsob2)
  (setq pgsob1(cdr(assoc -1(dictsearch(namedobjdict)"ACAD_PlotSettings"))))
  (setq pgslst '())
  (while (setq pgsob2 (dictnext pgsob1 (not pgsob2)))
      (setq pgslst(cons (cdr(assoc 1 pgsob2)) pgslst))
  (if(> (length pgslst) 1)(setq pgslst (aec_sort_lst pgslst <)))
 pgslst
you can then use this to test if "PDF.A1" page setup is already in the dwg:
(member "PDF.A1"(get_pgsetup_lst))
the above will return a list if "PDF.A1" is found or nil if not.
Paul Li
IT Specialist
@The Office
Message 17 of 29
Vuxvix
Hi!
Sorry for the late reply when I'm the one who needs help. Anyway, work still comes first.
I created another lisp to load the lisp you wrote: "Page SetupList"
 (write-line "(load\"PageSetupList\") " scrFile)
 (write-line "(load\"PS2A-PageSetup2AllLayout\") " scrFile)
 (write-line "(member "PDF.A1"(get_pgsetup_lst))" scrFile)
  (close scrFil)
However, line No.5 is wrong. I have tried adding "\" in multiple locations. But it's all wrong. So lisp doesn't work.
I also noticed that you are giving me the problem to complete. Thank you for your goodwill.
With my little knowledge, there are definitely many mistakes.
if you are comfortable with your time and mind. Please look into it for me.
Message 18 of 29
paullimapa
**modified with updates**
For line 5 whenever you're writing a statement and it contains a quote " then you have to precede it with a slash \:
(write-line "(member \"PDF.A1\"(get_pgsetup_lst))" scrFile)
But instead of what you're doing I would include as much as possible inside the single lisp file such as testing if
"PDF.A1" is there or not and if not then bring it in
PS2A-PageSetup2AllLayout.lsp:
; PS2A-PageSetup2AllLayout.lsp
; dwt - drawing template that contains the page setup name
(defun SetNamePageSetupAllLayouts (name dwt all / get_pgsetup_lst lst)
  (setq pgslst '())
  pgslst
 ; first test to see if pagesetup name is already in dwg
   (if(not(member name (get_pgsetup_lst)))
    (command "._-PSETUPIN" dwt name) ; if not then insert from template
   (if (vl-position
          name
      (progn
               (if all
(defun c:PS2A nil
   (SetNamePageSetupAllLayouts "PDF.A1" "Yaesu.dwt" T)
   (princ)
(defun c:PA21 nil
   (SetNamePageSetupAllLayouts "PDF.A1" "Yaesu.dwt" nil)
   (princ)
Then the one that writes the script file will just need to include the following lines to load the lisp & run either (c:PS2A) or (c:PS21):
 (write-line "(load\"PS2A-PageSetup2AllLayout\")" scrFile)
 (write-line "(c:PS2A)" scrFile)  ; for applying name to all layouts
; (write-line "(c:PS21)" scrFile) ; for applying name to current layouts
  (close scrFil)
Paul Li
IT Specialist
@The Office
Message 19 of 29
Vuxvix
1-with PS2A.lsp: Besides, Looks sound like when opening new file via script. Load PS2A lisp need confirm "allway load/ load once/.."
Command: PS2A
._-PSETUPIN Enter file name: ; error: bad argument value: AutoCAD command: T
2-With PAD.lsp:
  • Line is not needed anymore!?
Command: PAD
; error: bad argument type: streamp nil
Message 20 of 29
paullimapa
that error occurs because I had made a modification update to the lisp which you probably didn't pick up.
This line was this:
(defun SetNamePageSetupAllLayouts (name all dwt / get_pgsetup_lst lst)
I changed it to this:
So now PSA.lsp should work properly:
; PS2A.lsp
;; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-creat-script-batch-publish-multiple-file/m-p/12288211#M455772
  (setq pgslst '())
  pgslst
   (if (vl-position
          name
      (progn
               (if all
(defun c:PS2A nil
   (princ)
(defun c:PA21 nil
   (princ)
Give it a try again.
Paul Li
IT Specialist
@The Office
