Lisp Convert Objects To Polyline one time
Dears
I'm searching for lisp to change all objects(Circle, Arc , Line, ... etc.) to Polyline direct, all selected in one time.
Thanks for your support.
maratovich
^C^C(defun C:JPL ( / ope ssnab )(setq ope (getvar "PEDITACCEPT"))(setvar "PEDITACCEPT" 1)(setq ssnab (ssget "_I"))(while (not ssnab)(setq ssnab (ssget)))(command "_pedit" "_Multiple" ssnab "" "_Join" 0 "")(setvar "PEDITACCEPT" ope)(setq ssnab nil)(princ));JPL;
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Kent1Cooper
@maratovich wrote:
...(command "_pedit" ....
PEDIT won't do Circles.  For that, try CirclePolylineSwap.lsp >here<.  A routine could be built that would do that or equivalent to Circles, and use PEDIT on other things.
Kent Cooper, AIA
Kent1Cooper
@maratovich wrote:
....(command "_pedit" ... "_Join" ....
And there's a question for you, @Anonymous :  Do you want Lines and Arcs merely converted to single-segment Polylines individually, or do you want them Joined together where possible?  If you want them Joined, do you also want any already-existing Polylines that touch their ends also Joined to them?  The answer to that will affect what is permitted in object selection.
Kent Cooper, AIA
ВeekeeCZ
@Anonymous wrote:
... to change all objects(Circle, Arc , Line, ... etc.) to Polyline direct, all selected in one time. ...
This could help you even with most of those red ones.
Thanks to @_gile  for most of the subs.
Great, It's working as I need, thanks very much.
I need all Joined together. if also Join with any existing Polylines that touch their ends it will be great.
