lisp code to delete all dim objects and dim styles.
GeryKnee
GeryKnee
I need a lisp function that deletes all dimension objects from drawing, everywharw there are and the dimension styles.
Gery.
The (command "SELECTSIMILAR") Does not work?
Júnior Nogueira.
Por favor,  Aceitar como Solução se meu post te ajudar.
Please Accept as Solution if my post helps you
pbejse
@GeryKnee wrote:
 ...deletes all dimension objects ... the dimension styles.
Gery.
(defun c:demo (/ aDoc)
  (setq aDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
  (if (tblsearch "DIMSTYLE" "Standard")
    (command "-DIMSTYLE" "R" "Standard")
  (vlax-for blk	(vla-get-blocks aDoc)
    (if
      (eq :vlax-false (vla-get-isXref blk))
       (vlax-for h blk
	 (cond
	   ((and (vlax-write-enabled-p h)
		 (vl-string-search "Dimension" (vla-get-ObjectName h))
	    (vla-delete h)
  (repeat 4 (vla-purgeall aDoc))
(vl-load-com)
HTH
john.uhden
HTH is what I used to use to chlorinate my swimming pool.  🙂
Now I use something like 98% tri-chloro-dimescaline tablets (or something like that).
John F. Uhden
AIR_123
@pbejse wrote:
Gery.
    (if
       (vlax-for h blk
	 (cond
	    (vla-delete h)
(vl-load-com)
HTH
Great lisp! Thanks a lot!
How can it be optimized to also delete other styles, with possibility to delete by selection or style type? Thanks in advance!
Sea-Haven
You need to look into how to delete a dictionary entry, a simpler way is -purge look at the options.
