LISP code does not work in the Russian version of AutoCAD, letters are not displayed correctly in the editor.
galkin_vadim_prog
Message 1 of 24
galkin_vadim_prog
https://www.youtube.com/watch?v=g1pEGcQaYYw
(defun c:A4 ()
   (command "RECTANG" "0,0" "297,210")
https://www.youtube.com/watch?v=AW7RXho38_I
(defun C:HEXAGON (/ center radius angle p1)
(setq center (getpoint "\nSpecify center point: "))
(setq radius (getdist center "\nSpecify radius: "))
(setq angle (/ pi 3)); 60 degrees in radians
;; Create 6 points for the hexagon
(setq p1 (polar center (* 0 angle) radius))
(command "pline" p1)
(repeat 6
(setq p1 (polar center (* angle 1.0) radius))
(command p1)
(setq angle (+ angle (/ pi 3)))
(command "close")
(princ "\nHexagon created successfully.")
(princ)
Replies (23)
Message 21 of 24
galkin_vadim_prog
Waiting for a solution to the problem with AutoLISP
Message 22 of 24
paullimapa
yep, that's how it's designed so stick with 1 or 3 as shown in documentation:
https://help.autodesk.com/view/ACD/2018/ENU/?guid=GUID-1ED138FF-2679-45C4-9C2C-332A821C9D12
Paul Li
IT Specialist
@The Office
Message 23 of 24
paullimapa
best to submit a trouble ticket by signing into your Autodesk ID
Paul Li
IT Specialist
@The Office
Message 24 of 24
galkin_vadim_prog
VS work, AutoLISP not work
##- Введіть свою відповідь над цим рядком -##
