LISP by LeeMac SumAttributes.lsp | Version 1.1 to small edit
karpki
Message 1 of 11
karpki
Hi
The LISP is brilliant ang gives such result in the test file:
I need to hide first 4 digits from the name of the tag:
Before I used to add this kind of code for this purpose:
(setq lname(substr (setq str2 (car d)) 5 (- (strlen str2) 0)))
(vla-setCellValue Area_table crow 0 lname)
But here in this LISP I don't understand where to put something like that
Help needed please!
Thank you in advance for your interest!
BR
K
Replies (10)
Message 2 of 11
karpki
Forgot to tell, the simple correction of tag names is not the right way!
Message 3 of 11
devitg
@karpki  I try it , but do not work
(and (setq tag (if (cdr lst) (LM:listbox "Select Tags to Display" (mapcar 'car lst) 1) (mapcar 'car lst)))
                 (setq ins (getpoint "\nSpecify point for table: "))
                 ;(setq  tag (list (substr (car tag) 5 (- (strlen (car tag)) 0))))
Message 4 of 11
Lee_Mac
I'm pleased that you find my Sum Attributes program so useful.
To remove the first 4 characters from the displayed tag name, change line 112 from:
(setq lst (attsum:assoc++ (strcase (vla-get-tagstring att)) (fun att val) lst))
To:
(setq lst (attsum:assoc++ (strcase (if (< 4 (strlen (vla-get-tagstring att))) (substr (vla-get-tagstring att) 5) (vla-get-tagstring att))) (fun att val) lst))
Message 5 of 11
karpki
Hi Lee, glad to hear from you!
Thank you for your reply!
Indeed it was minused but the data order became wrong:
Ii should start from WF in this list
How to turn it back ?
Best Regards
K
Message 6 of 11
karpki
Hidden figures in the tag name should make an order in the tab.
Probably this is not possible here in this logic.
Normally I will have a list of 50-100 tag names and they should be in the correct order according the figures in the beggining of the name
But those figures are quite bad presenting in tab to see them
Message 7 of 11
Lee_Mac
In that case, revert to the original code, and instead change lines 120-122 from:
        (   (and (setq tag (if (cdr lst) (LM:listbox "Select Tags to Display" (mapcar 'car lst) 1) (mapcar 'car lst)))
To:
        (   (and (setq lst (mapcar '(lambda ( x ) (if (< 4 (strlen (car x))) (list (substr (car x) 5) (cadr x)) x)) lst))
Message 8 of 11
karpki
Thank you!
Superb!
Message 9 of 11
karpki
Oh, no!
Yes, it builds the tab by the correct order but
Unfortunatelly it ignores all the blocks and count only one of each different name
Message 10 of 11
Lee_Mac
Apologies - it should be the following:
        (   (and (setq lst (mapcar '(lambda ( x ) (if (< 4 (strlen (car x))) (cons (substr (car x) 5) (cdr x)) x)) lst))
Message 11 of 11
karpki
Yes!!!!!!!!!!!!!!!
Thank you very much!
