Lisp Batch process for turning frames on but does not print
Hi I am trying to create a lisp (but not working) to do a batch routine that will change all drawings pdf to on but does not plot.  Can anyone help?
Thanks!
hmsilva
Thanks!
Hello tbpbc and welcome to the Autodesk Community!
Additional explanations are required....
Are you trying to change PDFRAME?
Are you trying to change all PDF's references to a layer 'no plot'?
Henrique
I am trying to turn off a pfd frame.
hmsilva
Quick and dirty:
(defun c:demo (/ ALE_BrowseForFolder DocCol DwgList FName)
    ;; by Marc'Antonio Alessi
    ;; Example: (ALE_BrowseForFolder "Select drawings folder")
    ;; Original BrowseForFolder by Tony Tanzillo
    (defun ALE_BrowseForFolder (PrmStr / ShlObj Folder FldObj OutVal)
        (vl-load-com)
        (setq
            ShlObj (vla-getInterfaceObject
                       (vlax-get-acad-object)
                       "Shell.Application"
            Folder (vlax-invoke-method ShlObj 'BrowseForFolder 0 PrmStr 0)
        (vlax-release-object ShlObj)
        (if Folder
            (progn
                (setq
                    FldObj (vlax-get-property Folder 'Self)
                    OutVal (vlax-get-property FldObj 'Path)
                (vlax-release-object Folder)
                (vlax-release-object FldObj)
                OutVal
    (if (and (setq FName (ALE_BrowseForFolder "Select folder to process: "))
             (setq DwgList (vl-directory-files FName "*.dwg"))
             (setq DocCol (vla-get-Documents (vlax-get-Acad-Object)))
        (foreach Dwg DwgList
            (setq Dwg (vla-Open DocCol (strcat FName "\\" Dwg) :vlax-false))
            (if (/= (vlax-invoke Dwg 'getvariable "PDFFRAME") 2)
                (progn
                    (vlax-invoke Dwg 'setvariable "PDFfRAME" 2)
                    (vla-Close Dwg :vlax-true)
                (vla-Close Dwg :vlax-false)
    (princ)
Hope this helps,
Henrique
