- Mute
- Permalink
- Report
bad argument type: numberp: "PV-TEXT-NOTE"
the Set up code below:
(defun c:ldr (/)
;set variables
(setq LL (getvar "clayer") ML (getvar "cmleaderstyle"))
;Localize variables
(/ LL CC color ML h a v c pt)
(command "mspace")
(setq h (/ (getvar 'viewsize) 2/0))
a (apply '/ (getvar 'screensize))
v (list (* h a) h)
c (trans (getvar 'viewctr) 1/0)
(setq pt1 (mapcar '- c v) pt2 (mapcar '+ c v))
(command "mspace")
;setup
(setvar "clayer" "PV-TEXT-NOTE" "0.375")
(command "cecolor" "ByLayer")
(setvar "cmleaderstyle")
(setvar "ARIEL ANNOTATIVE" "1/8")
;equipment pad 1
(setq pt (getpoint "\nEQUIPMENTPAD1"))
(command "mleader" pt pause "nEQUIPMENTPAD1")
;equipment pad 1
(setq pt (getpoint "\nEQUIPMENTPAD2"))
(command "mleader" pt pause "\nEQUIPMENTPAD2")
;(e)structure
(setq pt (getpoint "\nSTRUCTURE"))
(command "mleader" pt pause "(E) \nSTRUCTURE")
;street
(setq pt (getpoint "\nSTREET1"))
(command "text" "style" "PV-TEXT-NOTE" pt "0.375" pause "Street1")
;street 2
(setq pt (getpoint "\nSTREET2"))
(command "text" "style" "PV-TEXT-NOTE" pt "0.375" pause "Street2")
;utility recloser pole
(setq pt (getpoint "\nUTILITY RECLOSER POLE"))
(command "mleader" pt pause "(N) n\UTILITY RECLOSER POLE")
;customer own goab
(setq pt (getpoint "\nCUSTOMER CUSTOMER GOAB"))
(command "mleader" pt pause "(N) n\CUSTOMER CUSTOMER GOAB")
;primary utility metering
(setq pt (getpoint "\nPRIMARY UTILITY METERING"))
(command "mleader" pt pause "(E) n\PRIMARY UTILITY METERING")
;property line
(setq pt (getpoint "\nPROPERTY LINE"))
(command "mleader" pt pause " n\PROPERTY LINE")
;site fence, type
(setq pt (getpoint "\nSITE FENCE, TYP"))
(command "mleader" pt pause " n\SITE FENCE, TYP")
;20' gravel access road
(setq pt (getpoint "\n20' GRAVEL ACCESS ROAD"))
(command "mleader" pt pause " n\20' GRAVEL ACCESS ROAD")
;site access gate
(setq pt (getpoint "\nSITE ACCESS GATE"))
(command "mleader" pt pause " n\SITE ACCESS GATE")
;mv trenching, typ
(setq pt (getpoint "\nMV TRENCHING, TYP"))
(command "mleader" pt pause " n\MV TRENCHING, TYP")
;tracker motor, typ
(setq pt (getpoint "\nTRACKER MOTOR, TYP"))
(command "mleader" pt pause " n\TRACKER MOTOR, TYP")
;site meter location
(setq pt (getpoint "\nSITE METER LOCATION"))
(command "mleader" pt pause " n\SITE METER LOCATION")
;restore settings
(command "dimstyle" "restore")
(setvar "cmleaderstyle" ML)
(setvar "clayer" LL)
(command "cecolor" color)
