LISP add a space to output
ryan.rettig
ryan.rettig
I have a LISP file i use for line numbers in my single line drawings. I would like to add a space before the number out put example below.
Currently I input the suffix like N -, i then get prompted for the starting number so example 101, its current out put would be N -101. I would like to change the file so it automatically adds a space between the suffix and the starting number.
Alfred.NESWADBA
No file attached.
If that lisp code works only with some specific dwg-structure or objects then a sample dwg-file would be great too.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
ryan.rettig
In the picture above i would type in the command for the LISP, it would prompt for a suffix in this case i put C- *enter* then it prompts for starting number 101 *enter* i then click the attributes or text i want to change. Currently it outputs like C -101 i would like to put a space between the suffix and prefix.
Kent1Cooper
[That's the prefix, not the suffix, but in any case....]
Change this:
(setq curStr(strcat rnm:Pref(itoa rnm:Start)))
to this:
(setq curStr (strcat rnm:Pref " " (itoa rnm:Start)))
But bear in mind that it will add that space in any usage of the routine, so you might want to make a separate one for when you want the space added, if you would ever want the capability of not  adding the space.
Kent Cooper, AIA
Moshe-A
Rayn,
if you add the space you want in respond to the prefix prompt then you would get exactly want you want - no?!
moshe
ryan.rettig
with how this LISP works it does not if i did the prefix and added a space or even a space before entering the starting number. This is why i was looking for a way to add it in the file which i have now found.
