lips for find block and put New Block from offcet location
I want to change Block insertation point based on previously added Block Referance... Is that possible?
and How?
Ex.
Insert block A at (0,0)
Insert Block B at offset from A at (5,3) so position of Block B is (15,13)
If I Insert Block A at (10,10)
Than lips required to insert Block B at offset From A (5,0) so position of B is (25,23)
DannyNL
Yes it is.
But I do not follow your examples you are giving. Block A on (0,0) and offset (5,3): why do you get new insertion point of (15,13)?
The same with your second example.
And do you want to insert a new block B or change the position of an existing block B?
Can you post an example drawing with before and after?
