linking current dimstyle text size to mtext size
kenhuse
Message 1 of 31
kenhuse
I have a lisp routine that draws an arc curved leader.
I have added an mtext command at the end.
To start with I would like to have the mtext size match that of the current dimstyle text size.
I should add that within my style dialog box the text size is currently set to 0.00.
Thanks for your help.
Accepted solutions (3)
Replies (30)
Message 21 of 31
Kent1Cooper
@kenhuse wrote:
Here's a drawing to experiment with. Thanks!
That drawing has apparently had its DIMSCALE System Variable setting changed.  If it's supposed to set the Dimension Style to SIMP1 on selection of one of those pieces of Text circled in hmsilva's image, I just set that as the current Style, and drew another Dimension.  The Text part came out twice as big as those, because I found the DIMSCALE value is 2.  Those Dimensions already in the drawing were apparently drawn with a DIMSCALE value of 1, but that's been changed since.  When I set DIMSCALE [back] to 1, my routine worked to set the Style to SIMP1 on selection of one of those Text objects.
Kent Cooper, AIA
Message 22 of 31
kenhuse
Good Morning Again Henrique,
I've done an analysis. I went through the dimstyles most often used, changed all the text height to .13.
I also went through each dimstyle and checked to see that under the fit tab, the "use overall scale" weren't rounded off and carried the last repeating digit out at least a half dozen times.
I then went and created text for each scale, sized according to the not rounded off number.
Then I did the most current version of the "demo" lisp.
I had success with: 3"=1', 1"=1', 3/4"=1',1/2"=1', 1/4"=1', 1/8"=1', 1/16"=1', 1"=10', 1"=20', and 1"=40 !!!
However, the routine returned "It was not possible to set current a dimension style from the selected text..." when I used it on: 6"=1', 1 1/2"=1', 3/8"=1', 3/16"=1', and 1"=30'.
I double checked to see that the "use overall scale" on the fit tab was correct on the ones that didn't work. The "use overall scale" for the ones that didn't work are as follows: .1666666666666 for 6"=1', .666666666666 for 1 1/2"=1', 2.6666666666 for 3/8"=1', 5.3333333 for 3/16"=1', and 30 for 1"=30'.
I don't see much of a pattern there.
For the ones that did work, the "use overall scale" were whole numbers except for 3"=1' which is .04333333, and 3/4"=1' which is 1.3333333.
I also looked at the various text sizes for the ones that worked versus the ones the worked and didn't see any pattern there either.
The mystery continues. Thanks again for your time and expertise, Ken
Message 23 of 31
kenhuse
Good Morning Kent,
I just sent this message to Henrique. I used his most current demo.lsp. ............
I apologize for not having tried the experiment with your .lsp, and will now to see what happens. I'll get back to you on that. However, for the time being here's what happened with Henrique's .lsp.
The mystery continues. Thanks again for your time and expertise Kent, Ken
Message 24 of 31
hmsilva
Hi Ken,
could you please test the attached code.
Henrique
Message 25 of 31
kenhuse
You're a god! It worked on every one! I'm so stoked. This is really cool.
I don't know how to do kudos. It's probably obvious however I'm new to this sort of collaboration and haven't solved the kodos mystery yet.
You deserve one from me for sure.  Thanks so much! Please tell me how to do kudos too, thanks!
Message 26 of 31
kenhuse
Hi again Kent,
Henrique sent me another .lsp and it now works on all the dimension styles! Thanks again for your input. Very much appreciated!, Ken
Message 27 of 31
hmsilva
You're welcome, Ken!
Glad I could help 🙂
For the Kudos >>> How do I give Kudos?  and this @philip.s article Getting Started Guide
Henrique
Message 28 of 31
kenhuse
Hello Henrique,
Hope you had a nice weekend.
I hesitate to ask, but am unable to resist, would you mind another tweak on the code?
The .lsp worked well in the "laboratory" but had mixed results in the "field".
The problem has to do with our dimstyle system where certain "use overall scale of" figures are rounded off.
I can circumvent this problem by modifying the dimstyles in each drawing and or resizing the text to the not rounded off figures.
Sorry to say, this is a big time consuming pain which renders the .lsp you created not very useful.
I'm not sure how this tweak could be accomplished. The .lsp fails on the repeating decimal text sizes.
It seems a shame to accept this shortcoming after all the brilliant work you've done.
It's possible that by limiting the number of decimal places (that the .lsp looks for) to 3 will solve the problem.
The repeating decimals in our dimstyle text sizes are variable. Not so great.
If I don't ever hear from you again, I won't hold it against you nor will I be overly surprised.
One way or another, I really appreciate all you've done and feel badly asking for more from your reserve of knowledge, especially since the need results from a inconsistency in our dimstyle system. Thanks again, Ken
Message 29 of 31
hmsilva
Hi Ken,
just, change
(equal ht (nth 3 x) 1e-6)
to
(equal ht (nth 3 x) 1e-3)
Hope this helps,
Henrique
Message 30 of 31
kenhuse
Henrique!, Success!!!!! Amazing! Thanks so much! Perfect!
I hope you have a nice week and that your expertise brings you what you most desire!, Ken
Message 31 of 31
hmsilva
You're welcome, Ken.
Glad I could help. 🙂
Henrique
