link selected block to nearest selected object in one determinated range
jtm2020hyo
jtm2020hyo
attached base lisp
attached dwg sample.
I have an attached lisp to link selected blocks to the nearest point of any selected objects...
works perfect, but now I need to limit the range angular. for example, divide the 360 degrees into quadrants
... quadrants (diagonal and "in cross" ) but per each block selected individually.
so the result should be something like this:
so this should be the result if you add the option for "quadrants in (D)iagonals" then choose the number "2", something like this:
and for "in (C)ross" quadrant "(2)"
then, if the block was rotated 180 degrees, then the quadrants should be rotated 180 degrees too.
jtm2020hyo
PD: if possible just add one determined angle, for example, drawing a line 90 degrees (variable) respect to the block rotation ( if the block have rotation 41, then the line is drawing in 131 degrees respect to the selected block base point), then link the selected object until touch him, if not possible because the line does not touch the selected object, then do nothing.
PD2: all lines should start since the block base point.
