Hello all,
This has been a problem for me for years. I was hoping that someone would know more bout it and perhaps even have a solution for it.
I have custom DOT linetypes with a very specific spacing (when both LTscale and the object linetype scale are 1.0). The spacing is critical as they are used in my profile grids and the dots coincide where grid lines intersect. If the pattern is off then the result is a somewhat random dot pattern. The dots have multiple purposes. One is to have dots that mark off standard measurements along both the horizontal and vertical grid lines. Another is to have black dots that appear to print as a gray line because of the white space between the dots. Yet another is to permit using the very compact compressed TIFF bi-tonal raster format as the plotter output because it neither makes the grid lines solid black or solid white but instead makes black dots where they are in the linetype definition.
Here is the linetype definition and an image of the incorrect spacing that is at each end of the lines:
*dot3d,dotted line ..................................
A,0,-0.066667
Authorized Autodesk Developer
Civil Design Specialist – Water & Wastewater Infrastructure
