line not shown in current view
jaggisingh003
Message 1 of 13
jaggisingh003
hello, Everyone please help me here.
I m working on something but get a problem whenever I execute this code in the current view this does not draw this  (command ".line" h st1 "") but whenever run this not in current view then this will work perfectly. I don't understand the problem.
(defun c:bkt (/ a l e f b a q h
p1 bk st1 st_l st_1 bt1 bt_1 st_inspt
bt_inspt st_y st
(setq l 2.90) ;(getreal "\n get the Setting distance")
(setq bk 2.00)
(setq e 1.400) ;(getreal "\n get the encumbrance")
(setq f 0.3)
(setq st_inspt 1.25)
(setq bt_inspt 2.5365)
(setq os (getvar "OSMODE"))
(setq b
(expt
(- (+ (expt (- l 0.2) 2) (expt (+ (- (+ e f) 0.156) 0.0705) 2))
(expt 0.110 2)
0.5
(setq q (/ (- (+ e f) 0.0855) (- l 0.200)))
(setq ang (+ (atan q) (atan (/ 0.11 b))))
(setq a
(expt (+ (expt (- bk (+ (+ e f) (+ (* 0.160 (cos ang)) 0.0705))) 2)
(expt (- (- l 0.125) (* 0.160 (sin ang))) 2)
0.5
(setq p1 (getpoint "\n get the start point"))
; get insertion point of bkt
(setq h (polar p1 (angtof "90.0") 20.0))
(command ".line" p1 h "")
(setq st1 (polar h (angtof "0.0") 1.25))
;mm line form last point of bkdist
(command ".line" h st1 "") ; draw line
(setq st_l (entlast)) ; set last drawn line st_l
(setq st_y (vlax-curve-getendpoint st_l))  ; get end point coordinates
(setq a (* 10 a))
(setq st_1 (polar st_y (angtof "0.0") a))
;final stay brkt length
(command ".line" st_y st_1 "")
(setq st (entlast));stay brkt for dimension
(setvar "OSMODE" os)
Replies (12)
Message 2 of 13
dlanorh
This looks like you need to (trans) the getpoint coords to wcs then trans st_y and st_1 to usc before drawing the line.
I am not one of the robots you're looking for
Message 3 of 13
jaggisingh003
@dlanorh. thanks for your suggestion I am new to lisp any example for this function. for more  help
Message 4 of 13
jaggisingh003
@dlanorh.  this not working (trans) Any other Suggestion
Message 5 of 13
jaggisingh003
This is happening with this code.
Message 6 of 13
dlanorh
How did you change the code?
(setq p1 (trans (getpoint "\n get the start point") 1 0)); getpoint = ucs insertion point of bkt so trans to wcs
(setq h (polar p1 (angtof "90.0") 20.0)); calc h in wcs
(command ".line" (trans p1 0 1) (trans h 0 1) "") ;draws line in ucs
(setq st1 (polar h (angtof "0.0") 1.25)) ;calc in wcs mm line form last point of bkdist
(command ".line" (trans h 0 1) (trans st1 0 1) "") ; draw line in ucs
(setq st_y (vlax-curve-getendpoint st_l))  ; get end point coordinates pt returned in wcs
(setq a (* 10 a))
(setq st_1 (polar st_y (angtof "0.0") a));final stay brkt length calc in wcs
(command ".line" (trans st_y 0 1) (trans st_1 0 1) "");draw in ucs
I hardly ever work in a ucs, so I'm very rusty, but substitute the above in your code lisp and see if this helps.
getpoint returns the point in the ucs so it needs to be transformed into wcs
vlax-curve-getendpoint returns a point in wcs
if all calculations are made in wcs and the points transformed to ucs when drawn you should end up with the correct geometry 🤞
If a coordinate is already in wcs, transforming it to wcs has no effect.
Message 7 of 13
jaggisingh003
@dlanorh thanks for this but not working 😭 😭.
Message 8 of 13
Kent1Cooper
Turn off running Object Snap and try again.  [This is almost always the source of the problem when things are not drawn where you expect them to be.]
My guess is that this:
is finding 'h' to be within the Object Snap aperture distance from 'st1', and is snapping [back] to the 'h' location.  When it fails, do you get a zero-length Line there at the corner?  And I'm guessing that somehow Osnap isn't in effect outside the viewing area, so that doesn't happen out there.
Kent Cooper, AIA
Message 9 of 13
jaggisingh003
@Kent1Cooper  do you get a zero-length Line there at the corner? -yes
yes getting a zero-length line.
Message 10 of 13
Kent1Cooper
That is what I expected.  So have you tried running it with Osnap off?
Kent Cooper, AIA
Message 11 of 13
jaggisingh003
 @Kent1Cooper  So what to do in this matter pls help  and tell me what to do.
Message 12 of 13
Kent1Cooper
I did already.  See the beginning of Message 8.  This from your screencast indicates that you have it turned on:
Kent Cooper, AIA
Message 13 of 13
jaggisingh003
thanks for your reply it helps me.
