Displaying program progress on screen not a progressbar
Message 1 of 13
I am writing a small game for AutoCAD in vb.net and would like to see the progress after each loop in the program. I tried committing the transaction with  regen for each loop and showing and hiding the main form but it only shows the final product. If I put a getstring in the loop it shows the progress up to that point but I don't want the user to have to keep hitting enter to see the progress. I wrote it in autolisp as well and that shows the progress with each step but its way too slow. Any suggestions would be welcome.
Thanks in advance.
Replies (12)
Message 2 of 13
dlanorh
Is this a .NET question (program progress) or a Lisp question (speed it up)? If it's the former, it's in the wrong Forum; if the latter, we can't help without seeing the code.
I am not one of the robots you're looking for
Message 3 of 13
pbejse
What approach did you use to show an on-screen  progress bar with lisp?  Do you mind posting your code so we could effectively give you better suggestions.
Message 4 of 13
_Tharwat
Good morning. 🙂
I guess the OP indicates to acets functions. eg: acet-ui-progress-init,safe,done.
Message 5 of 13
pbejse
@_Tharwat wrote:
Good morning. 🙂
You are probably right, I keep forgetting there are tons of  acet functions out there.
Anyway, back then,  i've taken the fill_image route with DCL to create a progress bar. Thats why i'm interested what the OP's approach was, could be something new.
Message 6 of 13
john.uhden
I was thinking about using a 2D solid and stretching it out horizontally over time...
(defun @progressbar (p10 height width / p11 p12 p13 w t1 t2 ent)
  (graphscr)
  (setq p12 (mapcar '+ p10 (list 0 height 0)))
  (setq w (* width 0.1))
  (setq p11 (mapcar '+ p10 (list w 0 0))
        p13 (mapcar '+ p12 (list w 0 0))
  (vl-cmdf "_.solid" "_non" p10 "_non" p11 "_non" p12 "_non" p13 "")
  (setq ent (entget (entlast)))
  (setq t1 (getvar "date"))
  (setq t2 t1)
  (while (< w width)
    (while (< (- (setq t2 (getvar "date")) t1) 1e-6))
    (setq w (+ w 1))
    (setq ent (subst (cons 11 p11)(assoc 11 ent) ent))
    (setq ent (subst (cons 13 p13)(assoc 13 ent) ent))
    (entmod ent)
    (setq t1 t2)
Well that didn't work too well.  A white screen just kept blinking at me until it ended, but at least the solid had grown.
John F. Uhden
Message 7 of 13
john.uhden
DOSLIB has a progressbar function.
John F. Uhden
Message 8 of 13
dlanorh
How about finding a use for the long forgotten Trace instead of a solid. You can still draw them using the ".trace" command.
Message 9 of 13
john.uhden
I dunno. Does the TRACE entity avoid the blinking screen issue?
Do traces have a width property? An LWPOLYLINE does.
John F. Uhden
Message 10 of 13
Sea-Haven
Maybe  a (princ asq) the asq is the extended character of a filled sq.  will go across command line.
(Repeat 25
(princ (chr 149))
(command "delay" 200)
(princ)
Message 11 of 13
john.uhden
I think I have it figured, just nothing written yet... grdraw.
I'l try to get a rudimentary one working for testing purposes. Then will
have to adjust for pixel size and viewtwist. My LABEL_IT program uses
grdraw to create glyphs that emulate AutoCAD's object snaps. They are
amazingly fast..
John F. Uhden
Message 12 of 13
john.uhden
Okay, here ya go.  A progressbar function in plain AutoLisp
(defun @progressbar (ang color % / i 1/2pi pixel nh ss vc vw LL UR p p1 p2 p3 p4)
  ;; ang is the horizontal angle of the bar in preparation for handling twisted views (future)
  ;;   It currently works only for an angle of zero in a non-twisted view
  ;; color is any of the normal AutoCAD color integers from 1 though 255
  ;; % is an integer representing the percent progress
  ;; Note that all these computations are repeated with each change in % because the user
  ;;   may have zoomed in or out randomly any number of times, so the values can keep changing.
  ;; The position of the bar in this initial release is always at the lower left corner of the screen.
  ;; It is intended that future releases will provide options for TL, TC, TR, BL, BC, BR
  ;; The dimensions were selected to please the author;
  ;;    feel free to change them to please yourself.
  (setq i 0.0
        1/2pi (* 0.5 pi)
        ss (getvar "screensize") ;; in pixels
        vc (getvar "viewctr") ;; in dwg units
        vs (getvar "viewsize") ;; view height in dwg units
        vw (* vs (apply '/ ss)) ;; view width in dwg units
        wid (* 0.25 vw) ;; bar width in dwg units
        ht (* 0.15 wid) ;; bar height in dwg units
        pixel (/ vs (cadr ss)) ; pixel height in dwg units
        nh (fix (/ ht pixel))
        LL (mapcar '- vc (mapcar '* '(0.5 0.5)(list vw vs)))
        UR (mapcar '+ vc (mapcar '* '(0.5 0.5)(list vw vs)))
        p (polar LL (angle LL UR)(* 0.05 (distance LL UR)))
        p1 p
        p2 (polar p1 1/2pi ht)
        p3 (polar p1 ang wid)
        p4 (polar p2 ang wid)
  (repeat (max 4 (fix (* nh 0.1)))
    (grdraw p1 p2 254) ;; border point
    (grdraw p2 p4 254) ;; border point
    (grdraw p1 p3 254) ;; border point
    (grdraw p3 p4 254) ;; border point
    (setq p1 (polar p1 (+ ang (* 1.25 pi))(* 1.414 pixel))
               p2 (polar p2 (+ ang (*  0.75 pi))(* 1.414 pixel))
               p3 (polar p3 (+ ang (*  1.75 pi))(* 1.414 pixel))
               p4 (polar p4 (+ ang (*  0.25 pi))(* 1.414 pixel))
  (setq p1 p)
  (repeat nh
    (setq p2 (polar p1 ang (* 0.01 wid %)))
    (grdraw p1 p2 color)
    (setq p1 (polar p1 1/2pi pixel))
(defun @progresstest ( / %)
  (setq % 0.0)
  ;; The following while loop is just for testing.
  ;; In real use, you must keep track of the % of progress, and
  ;; call the @progressbar function each time it changes.
  ;; In this test, just move your cursor around to see the progress,
  ;;    or type anything on the keyboard, or both.
  (while (and (grread 1)(<= % 100))
    (@progressbar 0.0 4 (setq % (1+ %)))
  (princ "\nDone.")
John F. Uhden
Message 13 of 13
Sea-Haven
Another method
(setq str "")
(setvar 'cmdecho 0)
(repeat 100
(setq str (strcat str "0"))
(setvar "modemacro" str)
(command "delay" 100)
(setvar "modemacro" "")
