Line break with set distance
dolman_gary
Observer Observer
Message 1 of 10
dolman_gary
Observer
Observer
I have seen multiple lisp routines that break lines but none that fit my need. I want to break a line at multiple points by setting a distance and picking intersections along the line as shown on the top vertical line in my screenshot.
I downloaded several routines that claimed to do this but none have worked successfully.
Replies (9)
Message 2 of 10
Kent1Cooper
You don't specify what you've tried, but >here< is one that worked for me.
with the difference [which I hope is acceptable] that you don't pick the intersections, but rather the breaking Line(s) and the intersecting one(s) to be broken.  Works with Lines only.
[And you really mean the top horizontal line in the image.]
Kent Cooper, AIA
Message 3 of 10
dolman_gary
Observer
Observer
Kent, thanks for the Lisp, it works, with a little practice to get the picking order I can break horizontal or vertical.
Much Appreciated.
Message 4 of 10
Kent1Cooper
@dolman_gary wrote:
... I can break horizontal or vertical....
Or otherwise:
But it wouldn't let me do all of those collectively -- I had to do some, and then others.  I haven't studied the routine to figure out why, but maybe it can be fixed to allow more-multiple operation, or there are probably other routines out there that already do, and/or that work with additional object types.
EDIT:
One that does well at multiples [in very limited trial], and that works with both Lines and Polylines [including arc segments], is >here< from @john.uhden.  It turns the broken-off part(s) of broken ones, but not what remains of the originals, green, but if you don't want that, just remove or comment out this line:
; (vlax-put obj2 'Color 3) ; just to see the difference
Kent Cooper, AIA
Message 5 of 10
Sea-Haven
Is it leading to this as next step ?
Message 6 of 10
dolman_gary
Observer
Observer
Seahaven, is there a lisp to break lines and draw an arc as shown in your example?
Message 7 of 10
pendean
Community Legend
Community Legend
Have you had a chance to look yet?
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/simple-line-break-and-jump-autolisp/...
https://www.google.com/search?q=autocad+lisp+to+create+jumper+lines
Message 8 of 10
dolman_gary
Observer
Observer
This is what I get using that linejump lisp
Message 9 of 10
pendean
Community Legend
Community Legend
@dolman_gary If that one single LISP does not work for you, you can reach out to that author or try all the other lisps in reply to that original post that seems to offer additional solutions, as well as try the many other web-based solutions offered in the next link.
Message 10 of 10
Kent1Cooper
Which one is "that"?  There are several routines by that name in that topic, with progressive adjustments, including partial edit suggestions.  Have you tried the one at Message 30 there?
Kent Cooper, AIA
