Limited character input
saitoib
saitoib
Hi All!
I want to limit the characters I can type.
Currently, I have come up with the following code to do so.
Maybe there is a more standard code?
(defun c:test1 ( / val);ali is gloval
  (while (not (or
    (= val "L") (= val "l")	(= val "C") (= val "c")	(= val "R") (= val "r")))
    (cond
      ((setq val (getstring (strcat "\Enter attach position [right(R) center(C) left(L)]"
        (if ali (strcat "<" ali ">") "")
        (if (= val "") (setq val ali));if enter
  (setq val (strcase val));to capital letter
  (setq ali val)
Saitoib
dbroad
If I'm interpreting your problem correctly, look at the help files for initget, especially the bits value.
(initget 1 "Right Center Left" ) ;;use 0 to accept defaults and test for nil in getstring result
(setq val (getkword "\nEnter the attach position [Right/Center/Left] :"))
Architect, Registered NC, VA, SC, & GA.
saitoib
@dbroad
There was a special function for this.
Thank you very much.
Saitoib
Sea-Haven
Or this is a library function can be used in any code 3 lines of code.
(if (not AH:Butts)(load "Multi Radio buttons.lsp"))
(if (= but nil)(setq but 1))
(setq ans (ah:butts but "h"  '("Left center or right" "Left" "Centre" "Right"))) ; ans holds the button picked
saitoib
@Sea-Haven
This is cool.
Saitoib
