LIGHT LAYOUT LISP
7 REPLIES 7
Message 1 of 8
1503 Views, 7 Replies
LIGHT LAYOUT LISP
Hello, rehashing an old lisp ported by the owner. I would like to add the option to put a light in the center of the room. with an array of high hat/can lights around it.
;;------------------=={ Custom Block Array }==----------------;;
;;  Program will generate a rectangular array of a selected   ;;
;;  block with a specified number of rows and columns, with   ;;
;;  blocks spaced uniformly and aligned centrally between two ;;
;;  window corner points selected by the user.                ;;
;;  Upon calling the program, the user is prompted to select  ;;
;;  a block to be arrayed. Following a valid selection, the   ;;
;;  user is then prompted to specify the number of rows and   ;;
;;  columns for the array, with the previously entered        ;;
;;  figures available as default values.                      ;;
;;  A prompt then asks the user whether grid-lines are to     ;;
;;  be constructed, such grid-lines intersect at the          ;;
;;  insertion points of each block in the array and extend    ;;
;;  to the limits set by the selected corner points.          ;;
;;  The user is then prompted to pick two corner points of an ;;
;;  array window, and the selected block is arrayed evenly    ;;
;;  between these points, with equal spacing.                 ;;
;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
;;  Version 1.1    -    14-09-2011                            ;;
(defun c:bArray
        *error* _StartUndo _EndUndo _SelectIf
        acdoc bl hd layer msg p0 p1 p2 p3 p4 vd x1 xd yd
    (setq layer "EST_E_LIGHTING-CONSTRUCION-LINES")  ;; Layer for Grid Lines (created if not present)
    (defun *error* ( msg )
        (if acdoc (_EndUndo acdoc))
        (if (not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*"))
            (princ (strcat "\nError: " msg))
        (princ)
    (defun _StartUndo ( doc )
        (_EndUndo doc)
        (vla-StartUndoMark doc)
    (defun _EndUndo ( doc )
        (if (= 8 (logand 8 (getvar 'UNDOCTL)))
            (vla-EndUndoMark doc)
    (defun _SelectIf ( msg pred )
            (lambda ( pred / sel )
                (while
                    (progn (setvar 'ERRNO 0) (setq sel (car (entsel msg)))
                        (cond
                            (   (= 7 (getvar 'ERRNO))
                                (princ "\nMissed, Try again.")
                            (   (eq 'ENAME (type sel))
                                (if (and pred (not (pred sel)))
                                    (princ "\nInvalid Object Selected.")
                sel
            (eval pred)
    (if
        (and
            (setq bl
                (_SelectIf "\nSelect Block to Array: "
                    (function
                        (lambda ( x )
                            (and (eq "INSERT" (cdr (assoc 0 (entget x))))
                                (zerop
                                    (logand 4
                                        (cdr
                                            (assoc 70
                                                (tblsearch "BLOCK" (cdr (assoc 2 (entget x))))
            (progn (initget 6)
                (setq *rows*
                    (cond
                            (getint
                                (strcat "\nSpecify Number of Rows <"
                                    (itoa
                                        (setq *rows* (cond ( *rows* ) ( 10 )))
                        (   *rows*   )
            (progn (initget 6)
                (setq *cols*
                    (cond
                            (getint
                                (strcat "\nSpecify Number of Columns <"
                                    (itoa
                                        (setq *cols* (cond ( *cols* ) ( 10 )))
                        (   *cols*   )
            (progn (initget "Yes No")
                (setq *grid*
                    (cond
                            (getkword
                                (strcat "\nConstruct Grid-lines? [Yes/No] <"
                                    (setq *grid* (cond ( *grid* ) ( "Yes" )))
                        (   *grid*   )
            (setq p1 (getpoint "\nSpecify First Corner of Array: "))
            (setq p2
                    (if (zerop (getvar 'WORLDUCS))
                        getpoint
                        getcorner
                    "\nSpecify Opposite Corner of Array: " p1
        (progn
            (setq p0 (vlax-3D-point (trans (cdr (assoc 10 (entget bl))) bl 0))
                  bl (vlax-ename->vla-object bl)
                  hd (- (car  p2) (car  p1))
                  vd (- (cadr p2) (cadr p1))
                  xd (/ hd *cols*)
                  yd (/ vd *rows*)
                  x1 (- (car p1) (/ xd 2.0))
                  p3 (list x1 (- (cadr p1) (/ yd 2.0)) (caddr p1))
                  p4 (polar P1 (angle P1 P2) (/ (distance P1 P2) 2.0)))
            (_StartUndo
                (setq acdoc
                    (vla-get-activedocument (vlax-get-acad-object))
            (repeat *rows*
                (setq p3 (list x1 (+ (cadr p3) yd) (caddr p3)))
                (repeat *cols*
                    (vla-move (vla-copy bl) p0
                        (vlax-3D-point
                            (trans (setq p3 (list (+ (car p3) xd) (cadr p3) (caddr p3))) 1 0)
            (if (eq "Yes" *grid*)
                (progn
                    (setq p3 (list (car p1) (- (cadr p1) (/ yd 2.0)) (caddr p1)))
                    (repeat *rows*
                        (setq p3 (list (car p3) (+ (cadr p3) yd) (caddr p3)))
                        (entmakex
                            (list
                                (cons 0 "LINE")
                                (cons 8 layer)
                                (cons 10 (trans p3 1 0))
                                (cons 11 (trans (list (+ (car p3) hd) (cadr p3) (caddr p3)) 1 0))
                    (setq p3 (list (- (car p1) (/ xd 2.0)) (cadr p1) (caddr p1)))
                    (repeat *cols*
                        (entmakex
                            (list
                                (cons 0 "LINE")
                                (cons 8 layer)
                                (cons 11 (trans (list (car p3) (+ (cadr p3) vd) (caddr p3)) 1 0))
(command "insert" "light" p4)
            (_EndUndo acdoc)
    (princ)
(vl-load-com) (princ)
;;                         End of File                        ;;
I added = p4 (polar P1 (angle P1 P2) (/ (distance P1 P2) 2.0)))
trying to set the center of the room using p1 and p2
I added = (command "insert" "light" p4)
I would think that it would work like this,, eventually I would like the option to ask if you want to add a ceiling light or ,, a fan light.. yes or no
Any input please? Nick
7 REPLIES 7
Message 2 of 8
(setq P4 (polar P1 (angle P1 P2) (/ (distance P1 P2) 2.0)))
(command "insert" "light" p4 "" "" "")
(_EndUndo acdoc)
(princ)
I guess that I figured it out.. thanks
Message 3 of 8
(initget "Yes No")
(if (= "Yes" (getkword "\nAdd a light? [Yes/No] <Yes>: "))
(initget "Yes No")
(if (= "Yes" (getkword "\nAdd a Fan Light? [Yes/No] <No>: "))
(command "insert" "fb" p4 "" "" "")
(_EndUndo acdoc)
    (princ)
;;                         End of File                        ;;
Message 4 of 8
thanks for the rank up guys,, Godspeed!
Message 5 of 8
(defun C:barray2 (/ c1 c2 wid ht rows cols blk); = Lights in Rectangular [& orthogonal] Room
  (setq
    c1 (getpoint "\nCorner of room: ")
    c2 (getpoint "\nOpposite corner: ")
    wid (abs (- (car c1) (car c2)))
    ht (abs (- (cadr c1) (cadr c2)))
    rows (getint "\nNumber of rows (---): ")
    cols (getint "\nNumber of columns (|||): ")
  ); setq
  (command
    "_.minsert" "csof"
    (mapcar '+ ; insertion point
      (list (min (car c1) (car c2)) (min (cadr c1) (cadr c2))); lower left of room
      (list (/ wid cols 2) (/ ht rows 2)); fractions of width/height
    ); mapcar
    "" "" "" ; X, Y, rotation defaults -- edit if needed
    rows cols (/ ht rows) (/ wid cols); numbers and spacings
(setq c3 (polar c1 (angle c1 c2) (/ (distance c1 c2) 2.0)))
(initget "Yes No")
(if (= "Yes" (getkword "\nAdd a Light? [Yes/No] <Yes>: "))
(command "insert" "light" c3 "" "" "")
(initget "Yes No")
(command "insert" "fb" c3 "" "" "")
    (princ)
Hello, how do I set the defaults for the rows to (2), columns to (2)
and  a default Yes for add a light?
Thanks Nick
Message 6 of 8
Kent1Cooper
One way, if you want it always to default to 2 [not to remember your previous value and offer that, which is also possible]:
(setq
  rows
  (cond
    ((getint "\nNumber of rows (---) <2>: ")); User input
    (2); User Enter above [returns nil]
  ); cond
  cols
  (cond
    ((getint "\nNumber of columns (|||) <2>: "))
    (2)
  ); cond
); setq
For the light:
(initget "Yes No")
(if (/= "No" (getkword "\nAdd a Light? [Yes/No] <Yes>: "))
Kent Cooper, AIA
Message 7 of 8
in reply to: Kent1Cooper
  (setq
 ); setq
    (cond
  ); cond
  cols
  (cond
    ((getint "\nNumber of columns (|||) <2>: ")); User input
  ); cond
  (command
    "_.minsert" "csof"
    ); mapcar
(initget "Yes No")
(initget "Yes No")
    (princ)
Hrm,, its not setting the system variable. Pulling my hair out over here. 🙂
Nick
Message 8 of 8
Kent1Cooper
Your line to end the (setq) function:
); setq
is way too soon, and you omitted the variable name -- rows -- before the part that puts a value in it.
Kent Cooper, AIA
AutoCAD Inside the Factory
