welcome on forum.
Try if this is what you wanted. It writes lengths to CSV format.
(defun c:TryMe (/ s i e l fn)
(if (and(setq s (ssget '((0 . "LINE"))))
(setq fn (getfiled "Create Output File" "" "csv" 1)))
(progn
(setq s (_SortSSByXValue s))
(setq i (sslength s))
(while (setq e(ssname s (setq i (1- i))))
(setq l (cons (vla-get-length (vlax-ename->vla-object e)) l))
(ssdel e s)
(setq l (list (cd:CON_All2Str l nil)))
(if (LM:WriteCSV l fn)
(startapp "explorer" fn)
(princ)
;;www.CAD.PL
;;part of CADPL-Pack-v1.lsp
; Zmiana elementow listy na lancuchy tekstowe / Convert list elements onto strings ;
; Lst [LIST] - lista wejsciowa / input list ;
; Mode [T/nil] - nil = jak wynik z funkcji princ / as a result of the princ function ;
; T = jak wynik z funkcji prin1 / as a result of the prin1 function ;
; (cd:CON_All2Str '("A" "B" 1 3) nil) --> ("A" "B" "1" "3") ;
; (cd:CON_All2Str '("A" "B" 1 3) T) --> ("\"A\"" "\"B\"" "1" "3") ;
(defun cd:CON_All2Str (Lst Mode)
(mapcar
(function
(lambda (%)
(if Mode
(vl-prin1-to-string %)
(vl-princ-to-string %)
Lst
;;sort SS by Xcoord
(defun _SortSSByXValue (ss / lst i e add)
(if (eq (type ss) 'PICKSET)
(progn
(repeat (setq i (sslength ss))
(setq lst (cons (cons (setq e (ssname ss (setq i (1- i))))
(cadr (assoc 10 (entget e)))
lst
(setq add (ssadd))
(foreach e (vl-sort lst (function (lambda (a b) (< (cdr a) (cdr b))))) (ssadd (car e) add))
(if (> (sslength add) 0)
add
;; Write CSV - Lee Mac
;; Writes a matrix list of cell values to a CSV file.
;; lst - [lst] list of lists, sublist is row of cell values
;; csv - [str] filename of CSV file to write
;; Returns T if successful, else nil
(defun LM:writecsv ( lst csv / des sep )
(if (setq des (open csv "w"))
(progn
(setq sep (cond ((vl-registry-read "HKEY_CURRENT_USER\\Control Panel\\International" "sList")) (",")))
(foreach row lst (write-line (LM:lst->csv row sep) des))
(close des)
t
;; List -> CSV - Lee Mac
;; Concatenates a row of cell values to be written to a CSV file.
;; lst - [lst] list containing row of CSV cell values
;; sep - [str] CSV separator token
(defun LM:lst->csv ( lst sep )
(if (cdr lst)
(strcat (LM:csv-addquotes (car lst) sep) sep (LM:lst->csv (cdr lst) sep))
(defun LM:csv-addquotes ( str sep / pos )
(cond
( (wcmatch str (strcat "*[`" sep "\"]*"))
(setq pos 0)
(while (setq pos (vl-string-position 34 str pos))
(setq str (vl-string-subst "\"\"" "\"" str pos)
pos (+ pos 2)
(strcat "\"" str "\"")
( str )
;;written by psujek.krzysztof@gmail.com
