LENGTHEN total length variable
sjxyz
sjxyz
I had a lisp routine where I could pick an object as a source and then its length could be used as the Total Length for a Lengthen command on another object. It looks as if back when this routine worked, calling Lengten updated the System Variable PERIMETER with the length of the object measured. Now that New Total Length variable is stored somewhere else. Can anyone help me get this working?
The old routine is this:
;;---------------------=={ AsLongAs}==---------------------;;
;;aslongas matches line length to length of arc, pline or circle;;
(defun C:ASLONGAS (/ cmde obj len)
(setq cmde (getvar "cmdecho"))
(setvar "cmdecho" 0)
(setq obj (car (entsel "\nSelect object to measure: ")))
(command "_.lengthen" obj "")
(setq len (getvar "perimeter"))
(prompt "\nPick end of line to change: ")
(command "_.lengthen" "_t" len pause "")
(setvar "cmdecho" cmde)
(princ)
ВeekeeCZ
This is all you need to make it work
(defun C:ASLONGAS ()
  (command "_.lengthen" pause "_t" (getvar 'perimeter))
  (princ)
Kent1Cooper
The LENGTHEN command has grown more options, so more is needed to get out of it.  More Enters could be added to get past them, but try this to simply cancel the rest of it after selection of the source-of-length object:
  (command "_.lengthen" obj) (command)
  (princ)
Or simply:
(defun C:ASLONGAS (/ cmde)
  (setq cmde (getvar 'cmdecho))
  (setvar 'cmdecho 0)
  (command "_.lengthen" (car (entsel "\nSelect object to measure: "))) (command)
  (command "_.lengthen" "_t" (getvar 'perimeter) pause "")
  (princ)
Kent Cooper, AIA
sjxyz
Thanks both: I've gone for your second version Kent.
