Lengthen DYnamic command by Lisp
Lukasvop1
Lukasvop1
Hello guys, can you help me? I wanna use command for lengthen lines with only one lisp command. Default I must tipe Lengthen DY.
Thank you.
Kent1Cooper
(defun C:LEDY () (command "_.lengthen" "_dynamic"))
or a Tool Palette button with:
^C^C_.lengthen _dy
By the way, if DYnamic mode was the last way you used LENGTHEN, in using the basic command again you don't need to type in the DY, but can just hit Enter/space to accept that as the offered default.
Kent Cooper, AIA
Lukasvop1
Thank you, this save me lot of struggle, yes I know "enter" repeat last command but this is what I need.
