Length Field LISP by Lee Mac to modify -> old length, current length and the difference
eakos1
eakos1
if we are working with polylines we need to know the legth of it. For that I want to create a program which can make these three Mtexts.
I want to have three Mtext:
- Current length of polyline in attributive - Program from Lee Mac can do it
- Original length of polyline as normal Mtext - I can do it
- The Difference if the length changed
The program Area Field LISP by Lee Mac can create an attributive text which shows the length the polyline if it changed after a regen it shows the new length.
I've modified this program, I let simple run it and with entlast I can reach this text, take the content and create a simple Mtext with the length of the polyline in position1, which is not changing, it always shows the original length.
But I need a third attributive text with the difference in position2.
Can here someone help me with it?
I want to get something like this:
On the top is the part of the code what I created.
I simple added the whole program from Lee Mac - I know the half of it I could delete because the are part is not needed only the length part.
;;; This program based on the program Length Field form Lee Mac
;;; Creates additional not associative Mtext based on other associative text
(defun c:lf_extended ( / e ed text position position1 position2)
   (lengthfield nil "%lu6")
   (setq e    (entlast)
	 ed   (entget e)
	 text (cdr (assoc 1 ed))
	 position (cdr (assoc 10 ed))
	 position1 (polar position 0 30); Position for Mtext not associative
	 position2 (polar position (/ pi -2) 7); Position for Difference Mtext associative
   (command "Mtext" position1 "_none" "@" (text) "")
   (command "Mtext" position2 "_none" "@" (strcat "Difference: " text) "")
)		    ;end
;; Length Field Commands                                                ;;
;;;(defun c:lf  ( ) (lengthfield nil "%lu6"))            ;; Current units
;;;(defun c:lfm ( ) (lengthfield nil "%lu6%ct8[0.001]")) ;; Current units with 0.001 conversion factor (mm->m)
;; Area Field Commands                                                  ;;
;;;(defun c:af  ( ) (areafield nil "%lu6%qf1"))           ;; Current units
;;;(defun c:afm ( ) (areafield nil "%lu6%qf1%ct8[1e-6]")) ;; Current units with 1e-6 (0.000001) conversion factor (mm2->m2)
;;----------------------=={ Length & Area Field }==---------------------;;
;;  This program offers two commands to allow a user to generate a      ;;
;;  field expression referencing either the area or the                 ;;
;;  length/perimeter/circumference of one or more selected objects.     ;;
;;  In the case of selecting multiple objects, the field expression     ;;
;;  will reference the sum of the areas or lengths of all objects in    ;;
;;  the selection.                                                      ;;
;;  The user may opt to specify a point at which to create a new        ;;
;;  multiline text object housing the field expression, pick a table    ;;
;;  cell in which the field should be inserted, or select an existing   ;;
;;  single-line text, multiline text, multileader, or attribute to      ;;
;;  be populated with the field expression.                             ;;
;;  Upon issuing the command syntax 'LF' (Length Field) at the AutoCAD  ;;
;;  command-line, the program first prompts the user to make a          ;;
;;  selection of objects for which to return the length summation.      ;;
;;  At this prompt, the user may select any number of Arcs, Circles,    ;;
;;  Lines, 2D Polylines (light or heavy), or 3D Polylines.              ;;
;;  Alternatively, upon issuing the command syntax 'AF' (Area Field)    ;;
;;  at the AutoCAD command-line, the program will prompt the user to    ;;
;;  make a selection of objects for which to return the area summation. ;;
;;  Ellipses, Hatches, 2D Polylines (light or heavy), Regions, or       ;;
;;  Splines. If the selected object is open, the area is computed as    ;;
;;  though a straight line connects the start point and endpoint.       ;;
;;  The user is then prompted to specify a point or table cell to       ;;
;;  insert a field expression referencing the summation of the lengths  ;;
;;  or areas of the selected objects.                                   ;;
;;  At this prompt, the user may also choose the 'Object' option in     ;;
;;  order to populate the content of an existing annotation object      ;;
;;  with the field expression.                                          ;;
;;  Upon choosing this option, the user may select any single-line      ;;
;;  text (DText), multiline text (MText), single-line or multiline      ;;
;;  attribute, attributed block, or multileader (MLeader) with either   ;;
;;  multiline text or attributed block content.                         ;;
;;  If the user selects an attributed block or attributed multileader   ;;
;;  with more than one attribute, the user is presented with a dialog   ;;
;;  interface listing the available attributes, and is prompted to      ;;
;;  select a destination for the field expression.                      ;;
;;  The user may optionally predefine the target block/multileader      ;;
;;  attribute by specifying the attribute tag where noted at the top    ;;
;;  of the program source code.                                         ;;
;;  The resulting field expression will display the sum of the lengths  ;;
;;  or areas of the selected objects, formatted using the field         ;;
;;  formatting code specified at the top of each command definition.    ;;
;;  Author:  Lee Mac, Copyright © 2017  -  www.lee-mac.com              ;;
;;  Version 1.0    -    2017-08-06                                      ;;
;;  - First release.                                                    ;;
;;  Version 1.1    -    2017-08-06                                      ;;
;;  - Program modified to account for selection of existing annotation  ;;
;;    objects which already contain a field expression.                 ;;
;;  Version 1.2    -    2018-10-29                                      ;;
;;  - Restructured program to use standard LM:outputtext function.      ;;
;;  - Incorporated Area Field functionality and added new 'AF' command. ;;
;;  Version 1.3    -    2018-11-04                                      ;;
;;  - Changed 'c:lf' and 'c:af' commands to functions accepting an      ;;
;;    optional attribute tag and field formatting argument to enable    ;;
;;    the user to create multiple commands with varying parameters.     ;;
(defun lengthfield (tag fmt / *error* idx lst obj prp sel)
   (defun *error* (msg)
      (LM:endundo (LM:acdoc))
      (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")))
	 (princ (strcat "\nError: " msg))
      (princ)
   (LM:startundo (LM:acdoc))
   (setq prp
	     ("AcDbArc" . "ArcLength")
	     ("AcDbCircle" . "Circumference")
	     ("AcDbLine" . "Length")
	     ("AcDbPolyline" . "Length")
	     ("AcDb2dPolyline" . "Length")
	     ("AcDb3dPolyline" . "Length")
   (if
      (setq sel
	      (LM:ssget	"\nSelect objects to obtain total length <exit>: "
			(list
			   (list
			      '(000 . "ARC,CIRCLE,LINE,*POLYLINE")
			      '(-04 . "<NOT")
			      '(-04 . "<AND")
			      '(000 . "POLYLINE")
			      '(-04 . "&")
			      '(070 . 80)
			      '(-04 . "AND>")
			      '(-04 . "NOT>")
			      (if (= 1 (getvar 'cvport))
				 (cons 410 (getvar 'ctab))
				 '(410 . "Model")
	(LM:outputtext
	   tag
	   (if (= 1 (sslength sel))
	      (progn
		 (setq obj (vlax-ename->vla-object (ssname sel 0)))
		 (strcat
		    "%<\\AcObjProp Object(%<\\_ObjId "
		    (LM:objectid obj)
		    (cdr (assoc (vla-get-objectname obj) prp))
		    (if	(and fmt (/= "" fmt))
		       (strcat " \\f \"" fmt "\">%")
	      (progn
		 (repeat (setq idx (sslength sel))
		    (setq obj (vlax-ename->vla-object (ssname sel (setq idx (1- idx))))
			  lst
			      (vl-list*
				 (LM:objectid obj)
				 lst
		 (strcat
		    "%<\\AcExpr "
		    (apply 'strcat (reverse (cdr (reverse lst))))
   (*error* nil)
   (princ)
(defun areafield (tag fmt / *error* idx lst sel)
      (princ)
   (if
      (setq sel
	      (LM:ssget	"\nSelect objects to obtain total area <exit>: "
			(list
			   (list
			      '(000 . "ARC,CIRCLE,ELLIPSE,HATCH,*POLYLINE,REGION,SPLINE")
			      '(-04 . "<NOT")
			      '(-04 . "<AND")
			      '(000 . "POLYLINE")
			      '(-04 . "&")
			      '(070 . 88)
			      '(-04 . "AND>")
			      '(-04 . "NOT>")
				 '(410 . "Model")
	(LM:outputtext
	   tag
	      (strcat
		 (LM:objectid (vlax-ename->vla-object (ssname sel 0)))
		 ">%).Area"
	      (progn
		    (setq lst
			    (vl-list*
			       (LM:objectid (vlax-ename->vla-object (ssname sel (setq idx (1- idx)))))
			       ">%).Area>%"
			       lst
		 (strcat
		    "%<\\AcExpr "
   (*error* nil)
   (princ)
;; Output Text  -  Lee Mac
;; Prompts the user to specify a point at which to create an MText object containing the supplied string or to
;; select a table cell, text, mtext, multileader, attribute, or attributed block to be populated with the supplied string.
;; tag - [str] Optional target attribute tag
;; str - [str] Field expression or other text content
(defun LM:outputtext (tag str / ent enx flg idx obj oid sel tab tmp typ)
   (if
      (setq tmp
	      (ssget "_X"
		     (list '(0 . "ACAD_TABLE")
			      '(410 . "Model")
	(repeat	(setq idx (sslength tmp))
	   (setq tab (cons (vlax-ename->vla-object (ssname tmp (setq idx (1- idx)))) tab))
   (while
      (not
	 (progn
	    (if	flg
	       (progn
		  (setvar 'errno 0)
		  (initget "Point eXit")
		  (setq	sel
			  (nentsel "\nSelect text, mtext, mleader, attribute or attributed block [Point/eXit] <eXit>: ")
	       (progn
		  (initget "Object eXit")
		  (setq sel (getpoint "\nSpecify point or table cell [Object/eXit] <eXit>: "))
	    (cond
	       ((= 7 (getvar 'errno))
		(prompt "\nMissed, try again.")
	       ((or (null sel) (= "eXit" sel)))
	       ((= "Point" sel)
		(setq flg nil)
	       ((= "Object" sel)
		(not (setq flg t))
	       (flg
		(setq ent (car sel)
		      enx (entget ent)
		      typ (cdr (assoc 0 enx))
		      obj (vlax-ename->vla-object ent)
		(cond
		   ((and (= 2 (length sel)) (wcmatch typ "TEXT,MTEXT"))
		    (if	(vlax-write-enabled-p obj)
		       (LM:outputtext:puttextstring obj str)
		       (prompt "\nThe selected text object is on a locked layer.")
		   ((and (= "ATTRIB" typ)
			 (/= 'str (type tag))
		       (progn
			  (if (wcmatch (strcase str t) "*%<\\ac*>%*")
			     (LM:outputtext:updatefield ent)
		       (prompt "\nThe selected attribute is on a locked layer.")
		   ((and
		       (or
			       (setq tmp (cdr (assoc 330 enx)))
			  (and (setq tmp (last (cadddr sel)))
			       (= "INSERT" (cdr (assoc 0 (entget tmp))))
		       (setq tmp (vlax-invoke (vlax-ename->vla-object tmp) 'getattributes))
		       (or
			  (and (= 'str (type tag))
			       (setq idx (vl-position (strcase tag) (mapcar 'vla-get-tagstring tmp)))
			       (setq obj (nth idx tmp))
			  (and (not (cdr tmp))
			       (setq obj (car tmp))
			  (and (setq idx (LM:listbox "Choose Attribute" (mapcar 'vla-get-tagstring tmp) 2))
			       (setq obj (nth (car idx) tmp))
		       (progn
			     (LM:outputtext:updatefield (vlax-vla-object->ename obj))
		   ((and (= 2 (length sel)) (= "MULTILEADER" typ))
		    (setq typ (cdr (assoc 172 (reverse enx))))
		    (cond
		       ((and (<= acblockcontent typ acmtextcontent) (not (vlax-write-enabled-p obj)))
			(prompt "\nThe selected multileader is on a locked layer.")
		       ((= acmtextcontent typ)
			   (vla-regen (LM:acdoc) acactiveviewport)
			t
		       ((and
			   (= acblockcontent typ)
			   (setq tmp (LM:getmleaderattributes obj))
			   (or
				   (setq oid (cdr (assoc (strcase tag) tmp)))
				   (setq oid (cdar tmp))
			      (and (setq idx (LM:listbox "Choose Attribute" (mapcar 'car tmp) 2))
				   (setq oid (cdr (nth (car idx) tmp)))
			(LM:setmleaderattributevalue obj oid str)
			t
		       ((prompt "\nThe select multileader has no editable content."))
		   ((prompt "\nThe selected object is not text, mtext, multileader, attribute or attributed block."))
	       ((setq tmp (LM:getcell tab (trans sel 1 0)))
		(if (vlax-write-enabled-p (car tmp))
		   (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-settext (append tmp (list str)))))
		   (prompt "\nThe selected table cell belongs to a table on a locked layer.")
	       ((vla-addmtext
		   (vlax-get-property
		      (LM:acdoc)
			 'paperspace
			 'modelspace
		   (vlax-3D-point (trans sel 1 0))
		   0.0
		   str
(defun LM:outputtext:puttextstring (obj str)
   (vla-put-textstring obj "")
   ;; To clear any existing field
   (vla-put-textstring obj str)
   t
(defun LM:outputtext:updatefield (ent / cmd rtn)
   (setq cmd (getvar 'cmdecho))
   (setvar 'cmdecho 0)
   (setq rtn (vl-cmdf "_.updatefield" ent ""))
   (setvar 'cmdecho cmd)
   rtn
;; ssget  -  Lee Mac
;; A wrapper for the ssget function to permit the use of a custom selection prompt
;; msg - [str] selection prompt
;; arg - [lst] list of ssget arguments
(defun LM:ssget	(msg arg / sel)
   (princ msg)
   (setvar 'nomutt 1)
   (setq sel (vl-catch-all-apply 'ssget arg))
   (setvar 'nomutt 0)
   (if (not (vl-catch-all-error-p sel))
      sel
;; Get MLeader Attributes  -  Lee Mac
;; Returns an association list of attribute tags & object IDs for all attributes held by an mleader block
;; mld - [vla] MLeader vla-object
;; Returns: [lst] List of ((<Attribute Tag> . <Object ID>) ... )
(defun LM:getmleaderattributes (mld / rtn)
   (vlax-for obj (vla-item (vla-get-blocks (vla-get-document mld)) (vla-get-contentblockname mld))
      (if
	 (and
	    (= "AcDbAttributeDefinition" (vla-get-objectname obj))
	    (= :vlax-false (vla-get-constant obj))
	   (setq rtn (cons (cons (strcase (vla-get-tagstring obj)) (LM:intobjectid obj)) rtn))
   (reverse rtn)
;; Object ID (integer)  -  Lee Mac
;; Returns an integer representing the ObjectID of a supplied VLA-Object
;; Compatible with 32-bit & 64-bit systems
(defun LM:intobjectid (obj)
   (if (vlax-property-available-p obj 'objectid32)
      (defun LM:intobjectid (obj) (vla-get-objectid32 obj))
      (defun LM:intobjectid (obj) (vla-get-objectid obj))
;; Set MLeader Attribute Value  -  Lee Mac
;; obj - [vla] MLeader vla-object
;; idx - [int] Attribute Definition Object ID
;; str - [str] Attribute value
(defun LM:setmleaderattributevalue (obj idx str)
   (if (vlax-method-applicable-p obj 'setblockattributevalue32)
      (defun LM:setmleaderattributevalue (obj idx str) (vla-setblockattributevalue32 obj idx str))
      (defun LM:setmleaderattributevalue (obj idx str) (vla-setblockattributevalue obj idx str))
   (LM:setmleaderattributevalue obj idx str)
;; List Box  -  Lee Mac
;; Displays a DCL list box allowing the user to make a selection from the supplied data.
;; msg - [str] Dialog label
;; lst - [lst] List of strings to display
;; bit - [int] 1=allow multiple; 2=return indexes
;; Returns: [lst] List of selected items/indexes, else nil
(defun LM:listbox (msg lst bit / dch des tmp rtn)
   (cond
      ((not
	  (and
	     (setq tmp (vl-filename-mktemp nil nil ".dcl"))
	     (setq des (open tmp "w"))
	     (write-line
		(strcat	"listbox:dialog{label=\""
			msg
			"\";spacer;:list_box{key=\"list\";multiple_select="
			(if (= 1 (logand 1 bit))
			   "true"
			   "false"
			";width=50;height=15;}spacer;ok_cancel;}"
		des
	     (not (close des))
	     (< 0 (setq dch (load_dialog tmp)))
	     (new_dialog "listbox" dch)
       (prompt "\nError Loading List Box Dialog.")
      (t
       (start_list "list")
       (foreach itm lst (add_list itm))
       (end_list)
       (setq rtn (set_tile "list" "0"))
       (action_tile "list" "(setq rtn $value)")
       (setq rtn
	       (if (= 1 (start_dialog))
		  (if (= 2 (logand 2 bit))
		     (read (strcat "(" rtn ")"))
		     (mapcar '(lambda (x) (nth x lst)) (read (strcat "(" rtn ")")))
   (if (< 0 dch)
      (unload_dialog dch)
   (if (and tmp (setq tmp (findfile tmp)))
      (vl-file-delete tmp)
   rtn
;; Get Cell  -  Lee Mac
;; If the supplied point lies within a cell boundary,
;; returns a list of: (<VLA Table Object> <Row> <Col>)
(defun LM:getcell (lst pnt / dir)
   (setq dir (vlax-3D-point (trans (getvar 'viewdir) 1 0))
	 pnt (vlax-3D-point pnt)
   (vl-some
      '(lambda (tab / row col)
	  (if (= :vlax-true (vla-hittest tab pnt dir 'row 'col))
	     (list tab row col)
      lst
;; ObjectID  -  Lee Mac
;; Returns a string containing the ObjectID of a supplied VLA-Object
(defun LM:objectid (obj)
   (eval
      (list 'defun
	    'LM:objectid
	    '(obj)
	    (if	(wcmatch (getenv "PROCESSOR_ARCHITECTURE") "*64*")
	       (if (vlax-method-applicable-p (vla-get-utility (LM:acdoc)) 'getobjectidstring)
		  (list 'vla-getobjectidstring (vla-get-utility (LM:acdoc)) 'obj ':vlax-false)
		  '(LM:ename->objectid (vlax-vla-object->ename obj))
	       '(itoa (vla-get-objectid obj))
   (LM:objectid obj)
;; Entity Name to ObjectID  -  Lee Mac
;; Returns the 32-bit or 64-bit ObjectID for a supplied entity name
(defun LM:ename->objectid (ent)
   (LM:hex->decstr
      (setq ent	(vl-string-right-trim ">" (vl-prin1-to-string ent))
	    ent	(substr ent (+ (vl-string-position 58 ent) 3))
;; Hex to Decimal String  -  Lee Mac
;; Returns the decimal representation of a supplied hexadecimal string
(defun LM:hex->decstr (hex / foo bar)
   (defun foo (lst rtn)
      (if lst
	 (foo (cdr lst)
	      (bar (- (car lst)
		      (if (< 57 (car lst))
			 55
			 48
		   rtn
	 (apply 'strcat (mapcar 'itoa (reverse rtn)))
   (defun bar (int lst)
      (if lst
	 (if (or (< 0 (setq int (+ (* 16 (car lst)) int))) (cdr lst))
	    (cons (rem int 10) (bar (/ int 10) (cdr lst)))
	 (bar int '(0))
   (foo (vl-string->list (strcase hex)) nil)
;; Start Undo  -  Lee Mac
;; Opens an Undo Group.
(defun LM:startundo (doc)
   (LM:endundo doc)
   (vla-startundomark doc)
;; End Undo  -  Lee Mac
;; Closes an Undo Group.
(defun LM:endundo (doc)
   (while (= 8 (logand 8 (getvar 'undoctl)))
      (vla-endundomark doc)
;; Active Document  -  Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc	nil
   (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
   (LM:acdoc)
(vl-load-com)
(princ
   (strcat
      "\n:: LengthAreaField.lsp | Version 1.3 | \\U+00A9 Lee Mac "
      ((lambda (y)
	  (if (= y (menucmd "m=$(edtime,0,yyyy)"))
	     y
	     (strcat y "-" (menucmd "m=$(edtime,0,yyyy)"))
       ) "2017"
      " www.lee-mac.com ::"
      "\n:: \"LF\" for Length Field | \"AF\" for Area Field ::"
(princ)
;;                             End of File                              ;;
ВeekeeCZ
btw where is the test dwg file? I scrolled the page all the way down, could not see it. I don't believe you did not post it,... it's probably just me who could not find it.
eakos1
Hello,  is it really necessary in this case?  You juts draw a simple straight polyline and thats it. If it works here it is fine.
But anyway, I'll post it.
eakos1
Here is the sample file.
And I found a failure in my code - two unnecessary brackets between the "text".
(command "Mtext" position1 "_none" "@" (text)"")
ВeekeeCZ
Ok, I'll just post this example that I did some time ago. There should be all you need for your case.
And yes, it's always better to post an example. It makes things easier for us.
eakos1
Hello, thanks for this file.
I could manage with the help this routine my program - it works fine now. 🙂
Here is the code if someone interested in:
;;; This program based on the program from Z9E3zK5E from https://forums.autodesk.com/
;;; Creates Mtext for the length of the selected objects:
;;; - 1. current length - associative
;;; - 2. original length - not changing
;;; - 3. the difference if the length changed - associative
;;; The program pick up the color of the first object and use it for the created texts
;;; Created by Ákos Erdélyi
;;; v00: 2021.08.28
(defun c:lf_extended (/ selection_set e ed text position position1 position2 position3 p1 p2 e1 rectangle)
   (command "undo" "begin")
   (Len2Field)
   (setq selection_set (ssadd))
   (setq e	   (entlast)
	 ed	   (entget e)
	 position1 (polar (polar position 0 28) (/ pi 2) 3.4) ; Position for Mtext not associative
	 position2 (polar (polar position 0 1.5) (/ pi -2) 6.5) ; Position for Text "Difference: "
	 position3 (polar (polar position 0 30) (/ pi -2) 😎 ; Position for the different Mtext
	 p1	   (polar position (/ pi 1.7) 7)
	 p2	   (polar position (/ pi -12) 50)
;;;   (command "chprop" e "" "color" "255" "")
   (vla-put-color (vlax-ename->vla-object e) global:color)
   (command "Mtext" position1 "_none" "@" text "")
   (setq e1 (entlast))
   (vla-put-color (vlax-ename->vla-object e1) global:color)
   (ssadd e1 selection_set)
   (ssadd e selection_set)
   (command "Mtext" position2 "_none" "@" "Difference: " "")
   (vla-put-color (vlax-ename->vla-object (entlast)) global:color)
   (Len2Field_1 selection_set position3)
   (command "rectang" p1 p2)
   (setq rectangle (entlast))
   (command "pedit" rectangle "w" "1" "")
   (vla-put-color (vlax-ename->vla-object rectangle) global:color)
   (command "undo" "end")
   (princ)
)		    ;end
;;; This is from  Z9E3zK5E from https://forums.autodesk.com/
;;;- I've made a SUB rutine from it
;;;- Changed the opr from + to -
;;;- input data: point "pnt" and the selection set "ss"
(defun Len2Field_1 (ss pnt / asp adoc ent oid otp fld obj opr pfl pfb pfe)
   (vl-load-com)
   (setq opr "-"
	 siz (getvar 'TEXTSIZE)
   (setq asp (vla-get-modelspace (setq adoc (vla-get-activedocument (vlax-get-acad-object)))))
;;;  (vla-endundomark adoc) (vla-startundomark adoc)
   (setq *suf* "")
   (if (and (princ
	       "\nReguired LINEs, POLYLINEs or TEXT with regular numbers or TEXT with fields made by this routine, "
;;;           (setq ss (ssget '((0 . "*TEXT,LINE,LWPOLYLINE") (410 . "Model"))))
;;;           (setq *suf* (cond (*suf*)
;;;                             ((getstring T "\nSuffix: "))))
;;;           (setq pnt (getpoint "\nSpecify point: "))
	    (setq fld "%<\\AcExpr (")
      (progn
	 (repeat (setq i (sslength ss))
	    (setq ent (ssname ss (setq i (1- i)))
		  otp (cdr (assoc 0 (entget ent)))
		  oid (itoa (vla-get-objectid obj))
		  fld (strcat fld
			      (cond ((and (wcmatch otp "*TEXT")
					  (setq pfl (vla-fieldcode obj))
					  (setq pfb (vl-string-search "%<\\AcExpr (" pfl))
					  (setq pfe (vl-string-search ") \\f \"%lu2%pr1\">%" pfl))
				     (strcat (substr pfl (+ pfb 12) (- pfe pfb 11)) opr)
					  (not (zerop (atoi (cdr (assoc 1 (entget ent))))))
				     (strcat "%<\\AcObjProp Object(%<\\_ObjId " oid ">%).Textstring>%" opr)
				    ((wcmatch otp "*LINE")
				     (strcat "%<\\AcObjProp Object(%<\\_ObjId " oid ">%).Length>%" opr)
	 (if (/= fld "%<\\AcExpr (")
	    (progn
	       (setq fld (vl-string-right-trim opr fld)
		     fld (strcat fld ") \\f \"%lu2%pr1\">%" *suf*)
	       (setq obj (vla-addText asp fld (setq pnt (vlax-3d-point pnt)) siz))
	       (vla-put-Alignment obj acAlignmentMiddleCenter)
	       (vla-put-TextAlignmentPoint obj pnt)
;;;  (princ "\nTo SUFFIX reset type following in the command line: '(setq *suf* nil)'")
   (princ)
(defun Len2Field (/ asp adoc ss ent pnt oid otp fld obj opr pfl pfb pfe)
   (vl-load-com)
   (setq opr "+"
   (setq *suf* "")
   (if (and (princ
      (progn
		  fld (strcat fld
;;; RDI added this here: to get the color of the first entity
	    (if	(= i (- (sslength ss) 1))
	       (setq global:color (vla-get-color (vlax-ename->vla-object ent)))
	    )	    ;if
	 )	    ;repeat
	    (progn
   (princ)
eakos1
Finally I used up just your code not the program from Lee Mac.
Thanks again.
