Lenght of different diameter pipes to excel
Hello
I have drawings with different diameter pipe lines. I want to get bill of quantities of the drawings like how many length of each diameter in an excel sheet.
I uploaded one of the dwgs. diamteres are text which are closed to each other. Diameter pointers are intersect with the relative pipe line which can be helpfull.
Any help would be great
tnkhs
pbejse
This:
Where do one start and the other ends?
oh,
there is actually a sink or washstand in the middle of the line connecting to it. So diameter is changing. there are small horizontal blue lines intersection with blue lines. 25 diameter for example, is up to the intersection.
I uploaded again
many thanks
any help would be great
pbejse
It is not as easy as it looks ozgun.sen, be patient. hang in there.
many thanks
I had actually a similar problem in the https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/help-for-select-line-or-polyline-bas..... In the other problem, I had objects with att. But in this , I have Dtext with pointers. The lisp had solved in the url
