How many colors in a mtext
msarqui
Message 1 of 8
msarqui
Hi guys,
I am wondering if there is a way to know if a MTEXT has more than one color assigned?
Thanks for helping.
Marcelo
Replies (7)
Message 2 of 8
pbejse
(Defun _colorsofthewind (str_ l )
	(if (and
	    	(setq p (vl-string-search "\\C" str_))
		(setq str_ (substr str_ (+ 2 p)))
		(vl-some (function (lambda (s)
            			(if (wcmatch str_ s) s)))
				 '("*C#;*"  "*C##;*" "*C###;*"))
	    		(_colorsofthewind str_ (cons
				(substr str_ 2 (1- (vl-string-position 59 str_))) l ))
      		l
Message 3 of 8
pbejse
or (setq digits ( vl-some ... ( strcat “*C” s “;*”) s) .. ‘(“#” “##” “###”) and use digits as (strlen digits) for substr str_ ... instead of vl-string-position 59...
oh well, you guys know what i mean 🙂
Message 4 of 8
pbejse
My bad, I realize duplicates should be considered as well.
(Defun _colorsofthewind (str_ l  / p d f)
	(if (and
		str_
		(setq d (vl-some (function (lambda (s)
            			(if (wcmatch str_ (strcat "C" s ";*")) s)))
			      (if (member (setq f (atoi (substr str_ 2 (strlen d)))) l)
				  l (cons f l))
      		l
HTH
Message 5 of 8
msarqui
Sorry for the dumb question but:
(Defun _colorsofthewind (str_ / p d f)
str_  = text string
l = ? Entity name?
Message 6 of 8
pbejse
str_  = text string
l = ? Entity name?
Sorry as well msarqui, I did not explain the usage, l is a type LIST.
What i intended to do with the code is count ALL the colors that are used on selected MTEXT's , so
_$ (setq colordata (_colorsofthewind str colordata))
(6 67 9 175)
colordata as the collected colors after processing the selection sets.
Passing a nil value would also work if the user is intending to count colors per selected MTEXT.
_$ (setq colordata (_colorsofthewind str nil))
(6 67 9 175)
 Anyway, here's the iterative version
(Defun _colorsofthewind (str_ / l p d f)
	(while
              (and
		str_
				  l (setq l (cons f l))
      		l
(setq colordata (_colorsofthewind str)) $
(6 67 9 175)
HTH
Message 7 of 8
msarqui
(6 67 9 175)
(6 67 9 175)
I see now!
Many thanks,
Marcelo
Message 8 of 8
pbejse
msarqui wrote:
I see now!
Many thanks,
Marcelo
Good for you Marcelo. and You are welcome.
Cheers
