leaders slightly intelligently
neam
neam
Hi everyone:
Is it possible to direction and alignment of leaders slightly intelligently?
Kent1Cooper
Partway there, though all on the same side of the Polyline:  replace this line:
(command "leader" (car ptlist) (polar (car ptlist) (dtor 135) dis) "" "" "" mt "")
with this:
(command "leader"
  (car ptlist)
  (polar (car ptlist)
      (angle
        '(0 0)
        (vlax-curve-getFirstDeriv pl
          (vlax-curve-getParamAtPoint pl (car ptlist))
        ); ...Deriv
      ); angle
      (/ pi 2)
    dis
  ); polar
  "" "" "" mt ""
); command
Which produced this in your sample drawing:
But to get it to go toward the outside of the local bending or curving direction at each location would be a challenge.  It's a question of determining whether the + at line 4 should be - instead, based on the way the direction changes at the vertex.  It would likely mean a different way of stepping through the 'ptlist' variable, to retain access to the previous vertex for an angle comparison, but maybe there's a way around that.  And when the change in direction crosses the 0° direction, which happens several times in the example, things need to be calculated differently.
Kent Cooper, AIA
