Leader with Text
Leader with Text
bahman.jf.68
Leader with Text
bahman.jf.68
Hi all,
I'm trying to add a leader with block name, but the leader command create Mtext :
(command "leader" "lea" p1t p2 "" blkname "")
How can I modify the code to create leader with Text (no Mtext) and also change layer of the leader line.
Thanks in advance.
john.uhden
You mention block, but then you mention text (no Mtext).  Which is it?
For a block, you can create an insertion, then draw a leader without mtext, and then use QLATTACH to attach the leader to the insertion.
You can't attach a leader to plain text.
John F. Uhden
john.uhden
Just testing.
John F. Uhden
devitg
@john.uhden  Hi , did you note that BACK is BACK?
john.uhden
@devitg
Yes, I did. YAY!
John F. Uhden
