Visual LISP, AutoLISP and General Customization
Layout tab order as they appear
3 REPLIES 3
215 Views, 3 Replies
Hi everyone. I am currently try to find a way that will display all of my tabs in the order in which they appear. I used (layoutlist), but that only appears to list them in alphabetical order. For example, (layoutlist) lists my tabs in this order: ("Body" "Cutlist" "End"). The order they actually appear in is: "Cutlist" "Body" "End". Any ideas?
3 REPLIES 3
Try this one.
[code]
(defun GetLayoutList (Doc / LoList cnt tmpLo LoName)
(if (not Doc)
(setq Doc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
(setq LoCol (vla-get-Layouts Doc))
(setq cnt 0)
(repeat (vla-get-Count LoCol)
(setq tmpLo (vla-item LoCol cnt))
(if (/= (setq LoName (vla-get-Name tmpLo)) "Model")
(setq LoList (cons (cons LoName (vla-get-TabOrder tmpLo)) LoList))
(setq cnt (1+ cnt))
(mapcar
'(lambda (x) (car x))
(vl-sort LoList '(lambda (a b) (< (cdr a) (cdr b))))
[/code]
Tim
"A blind man lets nothing block his vision."
wrote in message news:5152478@discussion.autodesk.com...
Thank you very much!! That did exactly what I wanted.
You're welcome.
Tim
wrote in message news:5152573@discussion.autodesk.com...
”Boost
