layer rename
layer rename
layer rename
hello. this is layer rename lsp that is only a partial change.
I want to remove that input texts.
for example. if there are layer names.   aaabx1. aaavv2. aaaxy3. aaazz4... etc.
input "aaa"
bx1
vv2
xy3
zz4... etc
always thank you all for help.
(defun c:lann (/ old new doc)
 (vl-load-com)
 (and
 (setq old (getstring T "\nold\w string: "))
 (or
 (snvalid old 1)
 (prompt " Invalid string.")
 (setq new (getstring T "\nnew string: "))
 (or
 (snvalid new 1)
 (or
 (/= new old)
 (prompt " Same string.")
 (vlax-for layer
 (vla-get-layers
 (vla-get-activedocument
 (vlax-get-acad-object)
 (vla-put-name
 layer
 (vl-string-subst
 new
 old
 (vla-get-name layer)
 (princ)
ВeekeeCZ
Use the Rename command.
Old name *
New name: aaa*
dbhunia
Try this.....
(vl-load-com)
(and (setq old (getstring T "\nold string: "))
      (or (snvalid old 1) (prompt "\nInvalid string."))
(vlax-for layer (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
        (vla-put-name layer (vl-string-subst "" old (vla-get-name layer)))
(princ)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
thank you...
