Layer name need on object
ishaq03
ishaq03
Please I need help, Because  here MR Kent1cooper have been provided me this lisp before. For which I am grateful to
him this lisp create the horizontal and vertical  lines on closed polyline and circles. Just change the code where the layer should be different for horizontal and vertical lines after created on the closed polylines. for your reference I am attaching the lisp command
ronjonp
Assuming you want the crosshairs on the same layer as the object selected:
Kent1Cooper
Incorporating the suggestions over at the Hatch-pattern topic, try the attached.
The questions raised there remain....
EDIT:  But just so that they'll be here with the adjusted code if they matter to you, here they are again:
If it's important to you which Layer the horizontal one goes on and which Layer the vertical one goes on [when they are, in fact, horizontal and vertical], that would require some additional code.  Currently the routine simply draws between midpoints of segments [with extensions if specified], and doesn't know where a Polyline starts or in which direction it's drawn or whether its segments are orthogonal, or whether an Ellipse is orthogonally oriented, and therefore [except for a Circle] doesn't care whether the Lines it draws are horizontal and vertical.  That could be determined if it matters.  If it does, do your situations always result in horizontal and vertical Lines, and if not, what would determine which one goes on the Layer for horizontal ones and which for vertical?
Kent Cooper, AIA
