GETVAR for all layout tabs
murmanator
murmanator
Hello, in the program below, I am using GETVAR 'CTAB to switch a Mleader style based on whether Im in model space or paper space. Is there a way to change the part where it lists the layout tab names to instead work for ALL paper space tabs no matter the name? It works like this except if the tab has a different name than what is listed. Thank you
(defun c:redline (/ refltr)
(IF (EQ (GETVAR 'CTAB) "Model") (SETVAR 'CMLEADERSTYLE "Redline Model")
(IF (OR (EQ (GETVAR 'CTAB) "LANDSCAPE D 8")
(EQ (GETVAR 'CTAB) "LANDSCAPE D 10")
(EQ (GETVAR 'CTAB) "POOL B 8")
(EQ (GETVAR 'CTAB) "POOL C 8")
(EQ (GETVAR 'CTAB) "POOL D 8")
(EQ (GETVAR 'CTAB) "DETAILS B 8")
(EQ (GETVAR 'CTAB) "LANDSCAPE B 8")
(EQ (GETVAR 'CTAB) "LANDSCAPE C 8")
(EQ (GETVAR 'CTAB) "DEMO"))
(SETVAR 'CMLEADERSTYLE "Redline Paper")))
(vl-cmdf "_.mleader" pause pause (setq refltr (getstring T "\n\t =>> Enter note : ")))
(princ)
pbejse
Look into (layoutlist)
ronjonp
@murmanator
Try this .. no need to check for layout names if there are only two conditions ( modelspace and paperspace ).
(setvar	'cmleaderstyle
	(if (= (getvar 'cvport) 1)
	  "Redline Paper"
	  "Redline Model"
This assumes that the two mleader styles exist in the drawing.
murmanator
That's it, thank you ronjonp! I have another program that checks for the styles and loads them if not present. Thank you again.
