layer name explode ?
jaimuthu
Message 1 of 14
jaimuthu
i have layer name floor1 its a closed polyline  i want i explode the layer name of "floor1" object
(defun c:ExplodeFloor1Layer ()
  (setq layerName "floor1")
  (setq ss (ssget "_X" (list (cons 8 layerName))))
  (setq objCount 0)
  (if ss
    (progn
      (setq i 0)
      (while (< i (sslength ss))
        (setq ent (ssname ss i))
        (command "EXPLODE" ent "")
        (setq objCount (1+ objCount))
        (setq i (1+ i))
      (prompt (strcat "Exploded " (itoa objCount) " objects on layer '" layerName "'."))
    (prompt (strcat "No objects found on layer '" layerName "'."))
  (princ)
Replies (13)
Message 2 of 14
ВeekeeCZ
And whats your question?
Message 3 of 14
jaimuthu
i want explode the object using layer name
Message 4 of 14
ВeekeeCZ
So it seems that you have a code that does so...
Message 5 of 14
Kent1Cooper
If the issue is that something about the routine is not working as you expect, I have a likely cause.
The EXPLODE command works oddly when in an AutoLisp (command) function.  It will Explode only one thing.  If you give it a multiple-object selection set, only one thing in it will be Exploded.  And if you give it a single one, it does not require you to complete the selection, since it can't accept additional objects.  That means that you should not provide that "" at the end of the function, as you would for any other editing command involving object selection.
(command "EXPLODE" ent)
[There are other ways to get around that behavior, but this is easier.]
Kent Cooper, AIA
Message 6 of 14
stev98312
I found if I set QAFLAGS to 1, I can change all selected items. If QAFLAGS is 0, only one item is manipulated.
It's a poor example, but this changes all selected Leaders to the TEXT layer and explodes them(because changing drawing scale does not scale leaders):
(defun c:TTLX (/ ss1)
  (setvar "QAFLAGS" 1)
  (if (setq ss1 (ssget))
    (progn
      (command "_.chprop" ss1 "" "LAYER" "TEXT" "")
      (command "_.explode" ss1 "")
    (setvar "QAFLAGS" 0)
(princ)
Steve
Message 7 of 14
Kent1Cooper
@stev98312 wrote:
.... set QAFLAGS to 1....
That's one of the "other ways" I mentioned.  But if you use it, it's a good idea to build in *error* handling to ensure that it gets reset.  If something causes an error and it doesn't get reset, it can cause problems with other things.
Kent Cooper, AIA
Message 8 of 14
Sea-Haven
Maybe a manual way also,
LAYISO select an object on desired layer,
select objects or select all
Explode
Layuniso
I have the Layiso & layuniso toolbar displayed.
Message 9 of 14
Kent1Cooper
@Sea-Haven wrote:
.... UnLayiso ....
[That's LAYUNISO.]
Kent Cooper, AIA
Message 10 of 14
komondormrex
using vla-explode
	(setq objCount 0)
	(if ss
		(progn
		  	(setq i 0)
;		  	  	(command "EXPLODE" ent "")
				(if (null (vl-catch-all-error-p (vl-catch-all-apply 'vla-explode (list (vlax-ename->vla-object ent)))))
					(progn
						(entdel ent)
		  	  	(setq i (1+ i))
	(princ)
Message 11 of 14
ВeekeeCZ
Just using the built-in command... with its default report.
(defun c:ExplodeFloor1Layer ( / s)
  (if (setq l "Floor1"
	    s (ssget "_X" (list (cons 8 l))))
    (progn
      (initcommandversion)
      (command "_.explode" s ""))
    (princ (strcat "\nError: No objects found on '" l "' layer.")))
  (princ)
Message 12 of 14
Kent1Cooper
Since the Layer name is actually part of the command name, it seems pointless to put it into a variable -- just use it directly.  And since you talk about Polylines specifically, restrict selection to those, and you can just report how many there were, instead of needing to use a counter variable and check each Explode for whether it worked [whether it was an Explodable object].
This uses the other "other way" I had in mind to get around the issue of EXPLODE in a command function, already suggested by @ВeekeeCZ :
(defun C:ExplodeFloor1Layer (/ ss)
  (if (setq ss (ssget "_X" '((0 . "*POLYLINE") (8 . "floor1"))))
    (progn ; then
      (command "_.explode" ss "")
      (prompt (strcat "Exploded " (itoa (sslength ss)) " Polylines on layer 'floor1'."))
    ); progn
    (prompt (strcat "No Polylines found on layer 'floor1'.")); else
  ); if
  (prin1)
Consider whether to force the Layer to be unlocked, within the routine.
Kent Cooper, AIA
Message 13 of 14
jaimuthu
thanks its work fine
Message 14 of 14
Sea-Haven
Thanks Kent, corrected above.
A more global rather than 1 layer.
(setq lay (cdr (assoc 8 (entget (car (entsel "\nPlease select object for layer "))))))
(if (setq ss (ssget "_X" '((0 . "*POLYLINE") (cons 8 lay))))
