Allflat.lsp mesh with dinamic blocks
kibitotato
kibitotato
Found this code from Lee Mac on this site https://www.cadtutor.net/forum/topic/49101-automate-flattening-all-entities-residing-inside-blocks/
The problem is tha this lisp makes a mess with dinamic blocks...
Attached 2 files after and before using allflat
(defun c:allflat ( / d )
   (vlax-for b (vla-get-blocks (setq d (vla-get-activedocument (vlax-get-acad-object))))
       (if (= :vlax-false (vla-get-isxref b))
           (vlax-for o b
               (if (vlax-write-enabled-p o)
                   (foreach e '(1e99 -1e99)
                       (vlax-invoke o 'move '(0.0 0.0 0.0) (list 0.0 0.0 e))
   (vla-regen d acallviewports)
   (princ)
(vl-load-com) (princ)
 Any ideas how to fix this?
ВeekeeCZ
Not sure what desired outcome is, but I would convert all dynblocks to the "static" ones first.
kibitotato
I want to flat every object in the .dwg. The lisp works very fine but it also transformates the dinamic blocks and I can´t make it "static".
The point is move every Z coordinate of every object and block (even objetc inside blocks, arrays and objets inside arrays...) to z=0
pendean
Community Legend
Community Legend
@kibitotato very few tools that do all you want leave Dynamic Blocks intact. Sorry, just another limitation of that object type.
kibitotato
OK, so there is no solution possible for this thing... Thanks!!!
