layer change
layer change
HR2323
Message 1 of 24
layer change
HR2323
hi every one,
 Please help us, I am trying to layer the box and title in several drawing.
Bring the outer of the box into the layer and also want the title of the drawing in another layer as well. Each drawing has a name similar to the title.
Accepted solutions (3)
Replies (23)
Message 21 of 24
HR2323
@pbejse,
It does not work on small case or proper case (Toggle Case) of text.
Message 22 of 24
pbejse
@HR2323 wrote:
@pbejse,
Dont just say it, show us an example of what you are describing, I dont really like this back and forth @HR2323 , right from the start, i said put the worst kind of example. so that every condition is taken into consideration
Message 23 of 24
pbejse
a quick solution is remove strcase
From
(Setq Dname (strcase (getstring "\nEnter Drawing Number: ")))
(setq Dname (strcase (vl-string-right-trim "0123456789"
		    (getpropertyvalue  s "TextString"))))
To
(Setq Dname (getstring "\nEnter Drawing Number: "))
(setq Dname (vl-string-right-trim "0123456789"
Message 24 of 24
HR2323
@pbejse
Got a lot better than i expected...
Thanks a lot
