layer change lsp
layer change lsp
layer change lsp
hello, I wrote this lsp. but doesnt work. I wonder why not. some help me
(defun c:lxxx ()
(if (= (tblsearch "layer" "aaa") nil)
(command "-layer" "m" "aaa" "c" "250" "l" "center" "" ""))
(setq ss (ssget))
(command "-layer" "s" "aaa" "")
(command "change" "p" "" "p" "la" "aaa" "")
(princ)
hak_vz
Try to finish this task yourself. Follow commands parameters and look what is missing. YOu may use command chprop.
Miljenko Hatlak
Sea-Haven
Like other post, layer "make" sets current layer to the one just made, so no need to set it. A hint you can chprop SS.
ВeekeeCZ
Look at this command-line listing... I located for you the issue to fix.
HTH
thank you all
I missed it  ""
