-laydel command need to respond with Enter
jmayo-EE
Mentor Mentor
jmayo-EE
Hello everyone,
I am trying to learn lisp and my first task is to silent run Laydel to remove a layer and it's contents. I have this but the red "" for Enter does not seem to work. Is this the correct way to respond automatically with Enter?
(defun c:DeletePVCaseLayer ()
(command "-LAYDEL" "N" "PVcase PV Modules (detailed)" "" "Y")
(princ "\nLayer 'PVcase PV Modules (detailed)' has been deleted.")
(princ)
This is forcing user input at the command line.
Command: (load"LD")
C:DELETEPVCASELAYER
Command: LD
-LAYDEL
Select object on layer to delete or [Name]: N
Enter layer name or [?]: PVcase PV Modules (detailed)
Selected layers: PVcase PV Modules (detailed).
Select object on layer to delete or [Name/Undo]: Y
*Invalid selection*
Expects a point or Last/Name
; error: Function cancelled
******** WARNING ********
There are 4 block definition(s) which reference the layer(s) you are deleting.
The block(s) will be redefined and the entities referencing the layer(s)
will be removed from the block definition(s).
You are about to delete layer "PVcase PV Modules (detailed)" from this drawing.
Do you wish to continue? [Yes/No] <No>: Regenerating model.
Operation aborted.
Thanks for any insight and assistance,
John
John Mayo
Kent1Cooper
Works for me:
Command: (command "-LAYDEL" "N" "2" "" "Y")
-LAYDEL
Enter layer name or [?]: 2
Selected layers: 2.
You are about to delete layer "2" from this drawing.
Do you wish to continue? [Yes/No] <No>: Y
Deleting layer "2".
1 layer deleted.
[It doesn't work if the specified Layer is current, but in that case there is a message to that effect, which I don't see in your command history.]
Kent Cooper, AIA
jmayo-EE
Sorry please ignore, it is working.
John
John Mayo
jmayo-EE
Thanks for replying Kent. It does work for me as well. I must have not reloaded it during the failed test.
John
John Mayo
