keep only highest value text in selected text.
ravi82sharm
ravi82sharm
Hello, I have so many bunches of text and want to keep only the highest value in it. can anyone suggest to me the lisp for the same? thank you in advance.
hak_vz
Since you didn't  provided sample dwg here is code that works with selected text without filtering. Let suppose all selected text  has numerical values. To use this code move text entities aside or leave only this layer on.
(defun c:maxvaluetext ( / ss i lst)
	(setq  i -1 ss (ssget '((0 . "*text"))))
	(cond
		((and ss)
			(while (< (setq i (1+ i)) (sslength ss))
				(setq lst (cons (list (atof(cdr(assoc 1 (entget (ssname ss i))))) (ssname ss i)) lst))
			(mapcar 'entdel (mapcar 'cadr (cdr (vl-sort lst '(lambda (x y) (> (car x)(car y)))))))
	(princ)
Miljenko Hatlak
ravi82sharm
thank you it works. yes all values are numeric.
_Tharwat
Another way using AutoLISP vanilla.
(defun c:Test (/ int sel ent num big del)
  ;; Tharwat - Date: 10.Sep.2022	;;
  (and (princ "\nSelect texts : ")
       (setq int -1 sel (ssget "_:L" '((0 . "TEXT,MTEXT") (1 . "*#*"))))
       (while (setq int (1+ int) ent (ssname sel int))
         (or (and (setq num (distof (cdr (assoc 1 (entget ent)))))
                  (> num big)
                  (if del (entdel del) t)
                  (setq big num del ent)
             (entdel ent)
  (princ)
