- Mute
- Permalink
- Report
Hello all
I have a FOUNDATIONS drawing with sporadic lines with spaces of different Gaps
Is it possible to help to connect the lines to get one Poly-line FOR bases
I found the Gaps code
Could it be modified to get the desired result
vl-load-com)
(defun c:demo (/ *error* get_glob_real mk_circle flag hnd i lst obj ori pt pt1 pt2 ss ss1 ss2)
(defun *error* (msg)
(if command-s
(progn (command-s "_.-view" "_R" "temp_h")
(command-s "_.-view" "_D" "temp_h")
(vl-cmdf "_.-view" "_R" "temp_h" "_.-view" "_D" "temp_h")
(vla-endundomark acdoc)
(cond ((not msg))
((member msg '("Function cancelled" "quit / exit abort")))
((princ (strcat "\n** Error: " msg " ** ")))
(princ)
(defun get_glob_real (var msg mod prec def / tmpH)
(if (or (not var) (/= (type var) 'REAL))
(setq var def)
(initget 6)
(setq tmpH (getreal (strcat "\n" msg " <" (rtos var mod prec) ">: ")))
(if (/= tmpH nil)
(setq var tmpH)
var
(defun mk_circle (pt dia)
(entmake
(list
'(0 . "CIRCLE")
'(8 . "GAP")
(cons 10 pt)
(cons 40 (/ dia 2.0))
'(62 . 1)
(or acdoc (setq acdoc (vla-get-activedocument (vlax-get-acad-object))))
(vla-startundomark acdoc)
(vl-cmdf "_.-view" "_S" "temp_h" "_.ucs" "_W")
(if (and (setq *_max_fuzz (get_glob_real *_max_fuzz "\n Enter Maximum Gap" 2 3 1.00))
(setq *_min_fuzz (get_glob_real *_min_fuzz "\n Enter Minimum Gap" 2 3 0.001))
(setq *_dia (get_glob_real *_dia "\n Enter Circle Size" 2 2 0.50))
(princ "\n Select objects or <ENTER> for all: ")
(or (setq ss (ssget '((0 . "ARC,LINE,*POLYLINE,SPLINE"))))
(setq ss (ssget "_X" (list '(0 . "ARC,LINE,*POLYLINE,SPLINE") (cons 410 (getvar 'ctab)))))
(progn
(repeat (setq i (sslength ss))
(setq hnd (ssname ss (setq i (1- i)))
lst (cons (vlax-curve-getstartpoint hnd) lst)
lst (cons (vlax-curve-getendpoint hnd) lst)
(while lst
(setq pt (car lst)
lst (cdr lst)
(if (not (vl-some '(lambda (p) (equal p pt *_min_fuzz)) lst))
(if (and (vl-cmdf "_.zoom"
(setq pt1 (list (- (car pt) *_max_fuzz) (- (cadr pt) *_max_fuzz)))
(setq pt2 (list (+ (car pt) *_max_fuzz) (+ (cadr pt) *_max_fuzz)))
(setq ss1 (ssget "_C" pt1 pt2 '((0 . "ARC,LINE,*POLYLINE,SPLINE"))))
(if (setq ss2 (ssget "_C" pt pt '((0 . "ARC,LINE,*POLYLINE,SPLINE"))))
(progn
(repeat (setq i (sslength ss2))
(setq hnd (ssname ss2 (setq i (1- i)))
obj (vlax-ename->vla-object hnd)
pt_a (vlax-curve-getstartpoint hnd)
pt_b (vlax-curve-getendpoint hnd)
(if (or (equal pt_a pt 1e-6)
(equal pt_b pt 1e-6)
(setq ori hnd)
(setq flag nil)
(repeat (setq i (sslength ss1))
(setq hnd (ssname ss1 (setq i (1- i)))
(if (and (ssmemb hnd ss)
(not (eq ori hnd))
(<= (distance (vlax-curve-getClosestPointTo obj pt) pt) *_min_fuzz)
(setq flag T)
(if (null flag)
(if (ssmemb hnd ss)
(progn
(if (and (not (eq ori hnd))
(<= *_min_fuzz (distance pt (vlax-curve-getClosestPointTo obj pt)) *_max_fuzz)
(mk_circle pt *_dia)
(if (and (eq ori hnd)
(wcmatch (vla-get-objectname obj) "*Polyline,*Spline")
(= (vla-get-closed obj) :vlax-false)
(> (vlax-curve-getdistatparam obj (vlax-curve-getendparam obj)) *_max_fuzz)
(<= *_min_fuzz (distance (vlax-curve-getStartPoint obj) (vlax-curve-getEndPoint obj)) *_max_fuzz)
(setq lst (vl-remove-if '(lambda (p) (equal p pt *_min_fuzz)) lst))
(*error* nil)
(princ)
