Join a line to an object (block)
regisrohde
regisrohde
Hi
i want to join a line to an object and when a move the object one point of line which was linked to the objectshould move with it and another point should be fix on the its position.
thanks.
I need to link a line to an object with the request but below unanswered.
http://forums.autodesk.com/t5/net/join-a-line-to-an-object/m-p/2445881/highlight/true#M13574
Please mark this as the solution if it resolves your issue.Kudos gladly accepted.
Regis Rohde
marko_ribar
You can achieve this by using constraints... See my attachment...
HTH, M.R.
[EDIT : Only problem is that this thing works only in 2D - not 3D - I don't know why as it should be working...]
Marko Ribar, d.i.a. (graduated engineer of architecture)
regisrohde
Thank you!
I liked the idea.
It is possible to hold the line connected to a block?
Regis Rohde
