Fix routine - Multiply owned object
ВeekeeCZ
Consultant Consultant
ВeekeeCZ
Hi, I have wrote the simple routine for quick layer creation.
Spoiler
(defun C:QL ( / :CopyLayer new old)
 (defun :CopyLayer (new old / ed )
  (if (setq ed (entget (tblobjname "LAYER" old)))
    (entmakex (subst (cons 2 new)
		     (assoc 2 ed)
		     ed))))
  (setq old (if (setq ssl (ssget "_I"))
	      (cdr (assoc 8 (entget (ssname ssl 0))))
	      (getvar 'CLAYER))
	new "")
  (while (or (not (snvalid new 0))
	     (tblsearch "LAYER" new))
    (setq new (lisped old)))
  (if (:CopyLayer new old)
    (setvar 'CLAYER new))
  (sssetfirst nil nil)
  (princ)
The routine does what I wanted to. But it looks that its causing same serious issues in the drawing - Multiply owned object. I really tried to find the problem... but I am missing something fundamental. It causes the same problem with both entmake and entmakex.
Here is the log from AUDIT command.
Spoiler
Command: AUDIT
Fix any errors detected? [Yes/No] <N>:
Auditing Header
Auditing Tables
Auditing Entities Pass 1
Pass 1 12200   objects audited
Auditing Entities Pass 2
Pass 2 12200   objects auditedAcDbLayerTableRecord: "v_infr_n_DS++"
      Extension dictionary 149D3B Not this object       Set to this
                                  was not repaired.
Auditing Blocks
 38      Blocks audited
Total errors found 1 fixed 0
Erased 0 objects
Thanks in adnvance.
Ajilal.Vijayan
Hi BeekeeCZ,
I think the error only occurs when you are creating a new layer with the copy of Layer 0.
As layer 0 has some special role in autocad, may be your new layer also inheriting those properties.
I tried by creating a new layer manually and set that new layer as current.
Then I tried QL command and AUDIT didn't report any error.
ВeekeeCZ
Not sure if the sample helps, but here it is. (edit: wrote before i saw the Ajilals reply)
Using Autocad 2012.
(edit: Keep the sample as it is (no change of current layer or anything)
I try copybase with the object... works fine.
I pre-select the object and run routine QL: I add the suffix "++"... it creates the new layer.
I try copybase with the object again ...then I get: *Warning* Multiply owned object, handle "4F"
Ajilal.Vijayan
 When you run the routine QL: is the Currnet layer is 0 ?
  1. I tried with Current layer 0 and use QL to create a new layer, got the Multiply owned  error when use copybase command.
  2. Creating a new layer manually and that layer as currnet, use QL to create a new layer , didnt get any error when use copybase command.
In a new drawing can you try step no: 2 ?
Edit : Also if possible try by not making new layer in the code, if the Currnet layer is 0
ВeekeeCZ
Also if possible try by not making new layer if the Currnet layer is 0
I'am playing whith that for a while... I tried that as well... it works fine. 0 layer as current does not effect anything.
I did not mention one important thing. These layers come from dgn->dwg conversing using Redline software.
I thing I shoud replace (entmake (entsub)) with entmake layer creating from whole new list.
