Iterate through polyline segments using lisp
prgmdl
Message 1 of 25
prgmdl
Hi
How to iterate each segments of a 2d polyline to get properties using lisp? Thanks
Replies (24)
Message 21 of 25
prgmdl
Hi @ВeekeeCZ ,
The lisp works, thank you. Also, if i's not too much to ask, how do I get the arc radius if the polyline contains an arc segment?
EDIT: something like this?
Message 22 of 25
prgmdl
I will use the value to create an offset for individual segments of the polyline. I also just encountered where a polyline contains an arc, and I would like to get the radius or the point locaiton of its midpoint to recreate it another software.
Message 23 of 25
ВeekeeCZ
Radius must be calculated from the bulge and endpoints. See HERE
Message 24 of 25
Sea-Haven
Google "point location of pline midpoint autolisp" pretty sure have seen a post about this recently here.
Message 25 of 25
prgmdl
Hi @ВeekeeCZ, I was trying to do this now in VBA but somehow the GetWidth does not work, do you know how to do the same code using VBA?
