It is possible "get certain string from file name and change dimention scale " ?
Message 1 of 24
hello everyone!
To be specific.. if filename contains 1:100(1:200 or1:300...), it is the same as changing the scale of the dimensions
i found like someting below...
- read filename
(defun C:pTxt()
     (setq fname(getstring "\n Enter a valid file name: "))
      (if(setq f(open fname "r"))
       (while (setq txtLine(read-line f))
        (princ txtLine)
       (princ "\n Error - Could not find file")
- find certain string from list
(defun c:test(/ a yes)
(setq a (list "1" "2" "3"))
(setq yes (searchstring a "2"))
(if(= yes t)
(prompt "found")
(prompt "Not found")
- Change Dimension sclae
(defun c:Dimsc ( / *error* _StartUndo _EndUndo doc ss deflt old_b_scale alrim bp ojt )
(vl-load-com)
(defun *error* ( msg )
(and doc (_EndUndo doc))
(or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
(princ (strcat "\n** Error: " msg " **")))
(princ)
(defun _StartUndo ( doc ) (_EndUndo doc)
(vla-StartUndoMark doc)
(defun _EndUndo ( doc )
(if (= 8 (logand 8 (getvar 'UNDOCTL)))
(vla-EndUndoMark doc)
(setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
(if (ssget "_X" '((0 . "*DIMENSION")))
(progn
(setq *scl* 1)
(setq *oscl*
(cond
(getdist
(strcat "\nSpecify Overall Scale Factor(Specify Overall Scale Factor) <"
(rtos
(setq *oscl* (cond ( *oscl* ) ( 1.0 )))
( *oscl* )
(_StartUndo doc)
(vlax-for o (setq ss (vla-get-ActiveSelectionSet doc))
(mapcar
(function
(lambda ( prop value )
(if (vlax-property-available-p o prop)
(vlax-put-property o prop value)
'(LinearScaleFactor ScaleFactor) (list *scl* *oscl*)
(vla-delete ss)
(_EndUndo doc)
(princ)
Therefore, how can i mix these things to create what i want?
Please help me
thank you
Replies (23)
Message 21 of 24
Yes, it is clearly the character that is included in the filename.
It is just a (scale number) format like 'filename (scale 300) _ @'.
thanks.
Message 22 of 24
pbejse
It is just a (scale number) format like 'filename (scale 300)@ _ @'.
thanks.
This is the additional code:
(defun _validname&scale (str / p scl)
      (setq scl
      	(cond
              (	(setq p (vl-string-search "(SCALE" str))
               		(atoi (substr str (+ 8 p)))		)
              (	(and ( wcmatch str "*- 1-*#")
                     (setq p (vl-string-position 45 str nil t)))
                     	(read (substr str (+ 2 p)))		)
 (if (numberp scl) scl)
It will accept both formats,  where filename is filename - 1-100.dwg or filename  (scale 300) _ @Anonymous
Attached is the modified code. Please let us know it the program works for you.
pBe
Message 23 of 24
It works well.
Thank you for your favor.
I will post the final code in this post after some modifications.
(With user guide video)
Once again, thanks to pbejse.
Bless you.
Message 24 of 24
pbejse
@Anonymous wrote:
It works well.
Bless you.
Good for you kamilee2011
I may ask for a favor from you in the future with regards to BIM
You are welcome
Cheers
