Lisp that creates a text with dimensions of a rectangle
I need a LISP code that creates a text under the rectangle with the content as ( $RectangleHeight$ x $RectangleWidth$)
since i have over a hundred of objects like this, a code of it will be much appreciated. Thanks for the help
Kent1Cooper
First, try some Searching of this Forum.  There have been other threads about Text showing the dimensions of rectangles -- I think typically in the middle of the rectangles, but the positioning should be adjustable easily enough.  [But what your image shows is not what I would expect from the wording "under the rectangle" -- you will need to spell out the criteria for where it should be positioned.]
Kent Cooper, AIA
Im sorry about the wording but what i meant was something along the lines of:
Pick a Rectangle
Store width.PickedRectangle as XDIM
Store height.PickedRectangle as YDIM
Create Text at coordinates (RectangleMidPointx + 3, RectangleMidPointy - 3)
       with the following text "( $XDIM$, $YDIM$ )"
The positioning doesn't really matter, as I can move all of them myself
Kent1Cooper
Then I think you will find something already out there with a Search, and you can Move them from the middle of the rectangles if that's where it puts them and you don't easily see how to define the initial location differently.  You may need to adjust to add the parentheses around the Text, unless there's one out there that already does it that way -- I don't recall how others have wanted it spelled out.
But questions arise:  Are the rectangles always oriented orthogonally, or might some be at other angles?  [Some such routines may use the bounding box, rather than the lengths of the edges, which would give larger size numbers for one that's not orthogonal.]  Are they always closed Polylines?  [If they might ever be made of separate Lines, it would need to be done differently, though it would still be possible with selection of all of them.]
Kent Cooper, AIA
Ranjit_Singh
@Anonymous wrote:
Those look like fields to me in your image? Is that the goal or are you looking for static text/mtext entities?
