Isolate Layer on nested layers?
DC-MWA
DC-MWA
I have a program that uses 2 functions to isolate layers and unisolate layers after operation is complete.
I'm trying to get this to work with nested layers within xref drawings.
see below...
;;;;;;;;;;;;;;;;;;;;;;;;;;;LAYER ISOLATION AND RETURN DEFUNS;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun DO_LIS (/ l n lst)
(setq *Lays_Status1* nil
*Lays_Status2* nil
l '("~*|A-WALL" "A-WALL" "~*|A-DOOR" "A-DOOR" "~*|A-GLAZ" "A-GLAZ" "~*|A-AREA-SPCE" "A-AREA-SPCE" "~*|A-AREA-SPCE-IDEN" "A-AREA-SPCE-IDEN")
(vlax-for x (vla-get-layers
(vla-get-activedocument (vlax-get-acad-object))
(if (member (setq n (vla-get-name x)) l)
(progn
(cons (list n (vla-get-layeron x))
*Lays_Status1*
(vla-put-layeron x :vlax-true)
(progn
(setq *Lays_Status2*
*Lays_Status2*
(vla-put-layeron x :vlax-false)
(princ)
);END DO_LIS
(defun DO_LUN (/ l n as)
(setq l '("~*|A-WALL" "A-WALL" "~*|A-DOOR" "A-DOOR" "~*|A-GLAZ" "A-GLAZ" "~*|A-AREA-SPCE" "A-AREA-SPCE" "~*|A-AREA-SPCE-IDEN" "A-AREA-SPCE-IDEN"))
(if (and *Lays_Status1* *Lays_Status2*)
(cond ((setq as (assoc (setq n (vla-get-name x)) *Lays_Status1*))
(vla-put-layeron x (cadr as))
((setq as (assoc (setq n (vla-get-name x)) *Lays_Status2*))
*Lays_Status2* nil
(princ)
);END DO_LUN
What am I missing here?
;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;END LAYER ISOLATION AND RETURN DEFUNS;;;;;;;;;;;;;;;;;;;;;;;;;;;;
Moshe-A
@DC-MWA  hi,
Your layer list contain wild-card characters that are suits for (wcmatch). you can not compare such strings with other comparison function (= , eq or member) so to figure this out i add this anonymous function.
(setq _lmatch (lambda (s0 lst) (vl-some '(lambda (s1) (wcmatch s0 s1)) lst)))
and the usage is:
(_lmatch (vla-get-name x) L)
this anonymous function iterate through your database list (l) and compare it to the questioned layer and if it finds a match, (vl-some) stops and return the result of (wcmatch) which is T, otherwise it return nil.
beside that i can not test your code 😀 i do not have a sample dwg.
enjoy
Moshe
(defun DO_LIS (/ _lmatch ; local function
                 l n lst)
 ; Anonymous function
 (setq *Lays_Status1* nil *Lays_Status2* nil)
 (vlax-for x (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
  ; (if (member (setq n (vla-get-name x)) l)
  (if (_lmatch (setq n (vla-get-name x)) l)
   (progn
    (setq *Lays_Status1* (cons (list n (vla-get-layeron x)) *Lays_Status1*))
   (progn
    (setq *Lays_Status2* (cons (list n (vla-get-layeron x)) *Lays_Status2*))
  ); if
 (princ)
);END DO_LIS
; (setq l '("~*|A-WALL" "A-WALL" "~*|A-DOOR" "A-DOOR" "~*|A-GLAZ" "A-GLAZ" "~*|A-AREA-SPCE" "A-AREA-SPCE" "~*|A-AREA-SPCE-IDEN" "A-AREA-SPCE-IDEN"))
   (cond
   ); cond
  ); vlax-for
 ); if
 (princ)
);END DO_LUN
DC-MWA
Thank you, this seems to work, I need to test more.
Thanks again.
