ISO LISP coder, to make rollingball like lisp for text tool path/polyline
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
looking for a tool that will behave like Rolling ball but will find the midline (tool path) of all text (pocketed out text/font) in a selection box/area. I am new to AutoCAD so my terminology may be off. I have a need to be able to take a font/text string highlight all the text I want, and perform a rolling ball like “lsp” to find the center of the font and place the lines (your centerlines) on a new layer so my CAM software can engrave the font not mill it? hope this makes sense. Hope someone can help.
Even better I need to automate this at some point, if possible,
Background that may help.
I use CIM-TECH (Soild-CIM) software with AutoCAD for converting my SolidWorks multi body part into an AutoCAD dwg, then creating tool paths to features it recognizes, and I can assign rules to the tool paths. Well for CIM-TECH to engrave (one single cut on a sketch/line) not mill out (uses edge offsets) it needs a single line sketch. SolidWorks does not transfer sketches to AutoCAD, so I cannot use the engrave feature in Solid-SIM. It will transfer over a milled-out font/text, but Solid-CIM sees this as a pocket and mills it out, (super long machining time and does not work with ball or tapper mill. If I could get you or someone to make a tool “lsp” like asked above this would solve some issues and save us time. If you need any sample drawings or models to help. And yes, I would donate if not too expensive.
