Is there a way to make this LISP to count blocks inside another block?
Message 1 of 24
I use this LISP to count how many blocks there is inside my dwg.
I attached 2 jpeg to make more understandable.
The first one, (IMG_01) there's 3 blocks (A, B and C). And the text next to them count how many of them there is on my DWG.
The second one (IMG_02) shows the same blocks, but they are inside another block (let's call it ABC). When I use the recount LISP, it shows 0.
Is there a way to make this LISP comand to count those blocks when they are inside another block?
Here's the LISP recount I use.
(defun c:recount (/ block_list cnt env_name)
(setq block_list
(list
(cons '2 "A")
(cons '2 "B")
(cons '2 "C")
(foreach i block_list
(if
(setq ss (ssget "X" (list '(0 . "INSERT") i)))
(progn
(setq
cnt (itoa (sslength ss))
env_name (strcat "BLOCK_COUNT_" (cdr i))
(setenv env_name cnt)
(princ (strcat "\nSet " env_name " to " cnt))
(progn
(setq
cnt "0"
(command "_REGEN") ;_refreshes field values
(princ)
And here's DieselExpression I use on the texts next to the blocks (to count the block "A", for example)
$(getenv, BLOCK_COUNT_A)
I've done all this using this topic as reference, but my knowledge using LISP is very limited to help with my issue.
Replies (23)
Message 21 of 24
Moshe-A
yes it count also dynamic blocks
Message 22 of 24
ronjonp
Code removed.
Message 23 of 24
I'll take this as a solution to my specific problem despite all the effort you both put to solve!
Thank you!
Message 24 of 24
ahmed_ayoub
hello guys can some one explain to me how to add this code into AutoCAD , or if anyone have the lisp program itself kindly loaded , I have some following blocks inside the main blocks i want something to count this  following blocks??
