Is there a Lisp that can sum two texts and bring the total to the next text?
Oliver_C3D
Message 1 of 49
Oliver_C3D
Replies (48)
Message 21 of 49
Oliver_C3D
Lisp does not work properly in this section!
For example, adding 1 + 76.84 with 100.45 gives the result: 0 + 277.29 !!!
Message 22 of 49
devitg
Please state which  row to add to which row
Message 23 of 49
Oliver_C3D
Partial slope
Message 24 of 49
dlanorh
I did mention that the lisp assumed that the number before the "+" was in thousands of units, so firstly we need to establish whether this is metric chainages (the number before the "+" is in kms) or imperial chainages (the number before the "+" is in 100's of yards)?
I am not one of the robots you're looking for
Message 25 of 49
Oliver_C3D
Unit is metric
For example
1(km)+234(m).56(cm)
Message 26 of 49
devitg
@Oliver_C3D wrote:
Partial slope
partial slope , to which row
Message 27 of 49
Oliver_C3D
Hello Dear
Do you understand where the problem is?
@dlanorh
Message 28 of 49
dlanorh
Apologies, I'm in a different time zone.
I will try to solve the space issue around the "+" sign so that this is replicated in the final string. Until then, this works mathematically.
(defun rh:chg_str (lst n) (+ (* (atoi (car lst)) (expt 10 n)) (atof (cadr lst))))
(defun str_split ( del str / n ) (if (setq n (vl-string-search del str)) (cons (substr str 1 n) (str_split del (substr str (+ n 1 (strlen del))))) (list str)))
; = Sum of Numerical Texts into 2nd one selected
(defun C:SNT2 (/ el1 el2 sum tsum)
  (setq el1 (entget (car (entsel "\nFirst numerical Text object: ")))
        el2 (entget (car (entsel "\nSecond numerical Text object to have content changed to sum with First: ")))
        sum (+ (rh:chg_str (str_split "+" (cdr (assoc 1 el1))) 3) (rh:chg_str (str_split "+" (cdr (assoc 1 el2))) 3))
        tsum (rtos (rem sum 1000) 2 2)
  ); setq
  (setq sum (strcat (if (< sum 1000) "0" (itoa (fix (/ sum 1000)))) "+" (while (< (vl-position 46 (vl-string->list tsum)) 3) (setq tsum (strcat "0" tsum)))))
  (entmod (subst (cons 1 sum) (assoc 1 el2) el2))
  (princ)
);end_defun
Message 29 of 49
Oliver_C3D
Message 30 of 49
dlanorh
It works in my test drawing. If it doesn't work in yours then I will need a sample drawing in AutoCAD 2010 so I can see what is causing the error, or is this adding a chainage to a non chainage number i.e. 0+123.45 & 5.678
Message 31 of 49
Oliver_C3D
This Drawing
@dlanorh
Message 32 of 49
Oliver_C3D
You may send .lsp file may be correct!
Message 33 of 49
dlanorh
The drawing is not helpful as I don't know what you are trying to add together. That aside, try this amended version.
(defun C:SNT2 (/ t1 elst t2 l1 l2 sum tsum p txt)
  (setq t1 (cdr (assoc 1 (entget (car (entsel "\nFirst numerical Text object: ")))))
        t2 (cdr (assoc 1 (setq elst (entget (car (entsel "\nSecond numerical Text object to have content changed to sum with First: "))))))
  (setq l1 (if (vl-position 43 (vl-string->list t1)) (str_split "+" t1) (list "0" t1))
        l2 (if (vl-position 43 (vl-string->list t2)) (str_split "+" t2) (list "0" t2))
        sum (+ (rh:chg_str l1 3) (rh:chg_str l2 3))
        p (if (wcmatch t2 "* + *") " + " "+")
  ); setq
  (setq sum (strcat
              p
              (if (/= (vl-position 46 (vl-string->list tsum)) 3) (while (< (vl-position 46 (vl-string->list tsum)) 3) (setq tsum (strcat "0" tsum))) tsum)
  (entmod (subst (cons 1 sum) (assoc 1 elst) elst))
  (princ)
);end_defun
Message 34 of 49
Oliver_C3D
The truth is that you are wonderful.
You worked very hard and took the time.
Thank you very much.
@dlanorh
Thanks to the rest of the friends.
@devitg
@Kent1Cooper
@john.uhden
Message 35 of 49
devitg
I ask what row to add to what row  , as I think it can be made in a automatic way , as 3DFACES enclose all text in a row.  to be add and change to the other row.
Message 36 of 49
Oliver_C3D
please explain more
Message 37 of 49
devitg
pseudo code
 pick the origin row name
then pick the nearby 3dface
get the 3dface coordinates
get all mtext or text  inside such 3dface
make a copy ,  from 000 to 000 and put in a  new layer
select mtext at the new layer ,
explode all mtext , not the text
at the new layer there are  only text  at the same insertion point  as the original row
Now pick the text to add row , and  the nearby 3dface that enclose text to add
make such text-ss and copy the same way as before to a new layer
As the distance and direction from origin text  to text to add shall be some constant value ,
now the lisp could pick both values , and then  assign such new values at the destination or  ROW  to add
Hope you can understand , my english is no so good
That is why I ask from which row to  get value , to  which row add succh value and change at this row
example
original row : Partial Slope Distance
row to get value
Progres. Hrz. Distance
and row to set new value
the same ,
Message 38 of 49
Oliver_C3D
This seems interesting!
@dlanorh
Message 39 of 49
john.uhden
Hwy, Ron.
Isn't it good enough to...
Command: (vl-string-subst "" "+" "1+234.56")
"1234.56"
and then distof?
and then @formatsta?
John F. Uhden
Message 40 of 49
devitg
please tell me what row comply with it
